I am not sure how CA allocates memory, but you have set a REALLY big value for EPICS_CA_MAX_ARRAY_BYTES (1.6GB). Perhaps you should try setting it to be just a little bigger than the largest image you will use. Is your data 8-bit? If so then 400000 is big enough for the 640x480 array you mentioned.
Sent: Thu 9/9/2010 10:26 PM
To: [email protected]
Subject: Fwd: Re: ca client get waveform pv error
You have to set EPICS_CA_MAX_ARRAY_BYTES on both the server (IOC) and
client ends. On Sep 9, 2010, at 7:17 PM, wantianmin wrote:
>> Hi all,
>> I am use a edm client get a waveform pv(640*480 ),the IOC has enough
>> memory,but only one client can get the pv data,when another client try
>> to connect to this pv,the client get the error message:
>> CA value callback('pic1'): No data, CA status The requested data
>> transfer is greater than available memory or EPICS_CA_MAX_ARRAY_BYTES
>> But ,I set the EPICS_CA_MAX_ARRAY_BYTES to a big number(1600000000),is
>> there some other options need to be configured?
>> Thanks for your help.
>> wantianmin
Hi,Eric,
thanks for your reply,
I checked the shell command for running the IOC and the client,
The EPICS_CA_MAX_ARRAY_BYTES is both set to 1600000000,and
running one client is ok,but if I try to running 2 client at the
seem time,
the second client will complain about such error(CA value callback ...)
wantianmin
- Re: ca client get waveform pv error wantianmin
- Fwd: Re: ca client get waveform pv error wantianmin
<2010>
<2010>
