-> tt 0x1b22fd0 194e58 vxTaskEntry +60 : 1c286f4 () 1c28860 epicsTimeToStrftime+12a8: 1c28150 () 1c2868c epicsTimeToStrftime+10d4: 1c244ec () 1c24878 drvSerialGetFile+bac: scanOnce (1bdff10) 13eafc rngBufPut +e0 : bcopy () Hello, Jeff-- We have a large number of VxWorks IOC running ether-ip 2.19 and we have not seen this problem. From the limited information in the task trace, it looks like one of the check_xxx_callback functions in devEtherIP.c is calling scanOnce(rec). In dbScan.c, I'm guessing epicsRingPointerPush() is calling rngBufPut (or at least something nearby) which is calling bcopy which is apparently trying to use some memory which it shouldn't, throwing an exception. As Kay pointed out, the argument to scanOnce() should be a pointer to a record. As long as this is a valid pointer to a valid record, I don't see how this exception could be caused by a bug in ether-ip. Can you poke around 0x1bdff10 and see what's there? If it is not really a record, try to get some more information as to what is happening (EIP_verbosity=7 or more, maybe recompile devEtherIP without static for the check_xxx_callback functions so the trace will tell us which one, set record TPRO=1, etc). Also, can you run your IOC stripped down without the other device drivers? It could be that some other driver is clobbering some memory somewhere which ether-ip is stumbling over. -- Steven Hartman [email protected] || 865-466-6473
ANJ, 09 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
