1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Please do not hijack threads [was: cPCI]
To: leige <[email protected]>
Date: Wed, 08 Sep 2010 10:48:13 -0400
Hello Ge,
Hijacking threads is happening a lot, not just to you, not just on tech talk. Don't worry.
Here's a bit more explanation of what is happening:
Emails contain lots of header lines before the message. Most of these header lines are filtered out by your email client program (e.g. Outlook), so you never see them.
(There should be an option like "show all information" or "show all headers" in your client, if you want to have a look what the email message really looks like.)
Some of these headers contain information, which other emails this one is a reply to. These header lines (that start with "In-Reply-To:" or "References:") can define long chains of emails, that are referred to as a thread.
Among a couple of other other bad things, Outlook and Outlook Express ignore the "In-Reply-To:" and "References:" headers and only use the "Subject:" line to sort emails into threads. Almost all other programs act correctly by ignoring the "Subject:" and using the "In-Reply-To:" and "References:" headers.
If you hit "Reply" , the whole chain of "In-Reply-To:" and "References:" headers is copied into your new mail. So - even if you change the "Subject:" line and Outlook shows your mail as the start of a new thread, the mail headers say it belongs to the other thread you were replying to, and all other applications will show it as part of that other thread.
Bottom line:
When starting a new question by email (in general, not just in tech talk), hit the "New message" button in your client and do not use "Reply". That will make sure your new question starts a new thread that will be recognized as such by all clients and applications.
Best regards,
Ralph
On 07.09.2010 21:12, leige wrote:
Hi, All,
I apologize for this trouble. I did post the cPCI mail by replying a mail of "time stamp question", although I modified the topic. I use outlook express. And finally I noticed how strange it looks in http://www.aps.anl.gov/epics/tech-talk/2010/threads.php?expd=01293&page=16#16
Sorry for this chaos.
Ge
----- Original Message -----
To: "Maren Purves"<[email protected]>
Cc:<[email protected]>
Sent: Wednesday, September 08, 2010 3:51 AM
On 07.09.2010 15:46, Maren Purves wrote:
On Tue, 7 Sep 2010, Ralph Lange wrote:
Tech-Talk messages are keeping the original sender in the "From:"
header intact, so a simple "reply" should create a mail to the
original sender.
The "tech-talk-bounces" address is added in the "Sender:" and - more
importantly - "Errors-To:" headers to direct mail bounces to
mailman's automated bounce-handling mechanism.
This fully complies to the relevant RFCs and works without any
problem on most mail clients and with ten-thousands of lists that are
handled by mailman world-wide.
What mail client are you using that shows this erroneous behavior?
If it's supposed to work like that it probably does.
I use pine when I'm at home, seamonkey when I'm at work.
Those should be fine.
I know that Outlook does a bunch of non-compliant weird things wrt
replying to mails, so I was fearing the worst....
Happy mailing!
~Ralph
Time stamp question Andrew Wagner
cPCI leige
Please do not hijack threads [was: cPCI] Ben Franksen
Re: Please do not hijack threads [was: cPCI] Andrew Johnson
Re: Please do not hijack threads [was: cPCI] Maren Purves
Re: Please do not hijack threads [was: cPCI] Ralph Lange
Re: Please do not hijack threads [was: cPCI] leige
Prev: Re: Pete Jemian
Next: RE: sscan 2-6-6 does not build with cygwin DLL release version 1.7.7-1 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Please do not hijack threads [was: cPCI] leige
Next: EDM display fonts problem under Fedora 13. [SEC=UNCLASSIFIED] WANG, Jian
ANJ, 08 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
