Hi:
At the SNS, we're not using 64 bit Linux, so no effort is made to test our
CSS products on 64 bit.
Fundamentally, though, it seems to run when I quickly try it on a machine
that happens to be 64 bit.
uname -a
Linux ics-srv-epics1.ics.sns.gov 2.6.9-89.0.19.ELsmp #1 SMP Wed Dec 30
12:52:55 EST 2009 x86_64 x86_64 x86_64 GNU/Linux
java -version
java version "1.6.0_19"
Java(TM) SE Runtime Environment (build 1.6.0_19-b04)
Java HotSpot(TM) Server VM (build 16.2-b04, mixed mode)
CSS 2.2.0 starts up OK.
The Channel Access library plugin does NOT contain 64 bit binaries, so you
will have to use the pure java CAJ version (CSS, Preferences, ..., EPICS,
When you cannot launch CSS at all, try to run it like this:
css -consoleLog
There should be some error related to wrong Java version.
You will have to use a Sun/Oracle Java, not the GNU java compiler.
You can also try
css -consoleLog -vmargs -d32
to actually use the 32 bit version of Java.
Kay
On 9/8/10 10:12 , "John Dobbins" <[email protected]> wrote:
> All,
> I had previously installed CSS 2.0.1 under Linux x86.
> i.e.
> http://ics-web.sns.ornl.gov/css/updates/apps/sns_css_2.0.1-linux.gtk.x86.zip
> We are testing an x86_64 Linux and find that we cannot launch CSS. Is there
> any way to run CSS on a 64 bit machine?
> Thanks,
> John Dobbins
> Lab for Elementary Particle Physics
> Cornell University
- CSS on x86_64? John Dobbins
Re: Pete Jemian
<2010>
issues with drvEtherIP V2.19 - ControlLogix 5000 PLC via EtherNet/IP Jeff Hill
<2010>
