On Tue, 7 Sep 2010, Ralph Lange wrote:
On 07.09.2010 15:31, Maren Purves wrote:
On Tue, 7 Sep 2010, Andrew Johnson wrote:
> And while we're discussing the mechanics of tech-talk, please check your
> email
> address book for the address '[email protected]' and either
> delete
> it or add something like "DO NOT SEND TECH-TALK POSTS TO THIS ADDRESS"
> to the
> Name field.
Andrew,
if I reply to a message that comes from "tech-talk-bounces" I will
likely reply to "tech-talk-bounces". You'd have to edit the recipient
to avoid that.
No.
Tech-Talk messages are keeping the original sender in the "From:" header
intact, so a simple "reply" should create a mail to the original sender.
The "tech-talk-bounces" address is added in the "Sender:" and - more
importantly - "Errors-To:" headers to direct mail bounces to mailman's
automated bounce-handling mechanism.
This fully complies to the relevant RFCs and works without any problem on
most mail clients and with ten-thousands of lists that are handled by mailman
world-wide.
What mail client are you using that shows this erroneous behavior?
If it's supposed to work like that it probably does.
I use pine when I'm at home, seamonkey when I'm at work.
Maren>
- Re: Please do not hijack threads [was: cPCI] Ralph Lange
- Time stamp question Andrew Wagner
- cPCI leige
- Please do not hijack threads [was: cPCI] Ben Franksen
- Re: Please do not hijack threads [was: cPCI] Andrew Johnson
- Re: Please do not hijack threads [was: cPCI] Maren Purves
RE: Camera Link drivers for areaDetector? Timothy Madden
<2010>
<2010>
ANJ, 07 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
