1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Please do not hijack threads [was: cPCI]
To: [email protected]
Date: Tue, 07 Sep 2010 15:40:36 -0400
On 07.09.2010 15:31, Maren Purves wrote:
On Tue, 7 Sep 2010, Andrew Johnson wrote:
And while we're discussing the mechanics of tech-talk, please check your email
address book for the address '[email protected]' and either delete
it or add something like "DO NOT SEND TECH-TALK POSTS TO THIS ADDRESS" to the
Name field.
Andrew,
if I reply to a message that comes from "tech-talk-bounces" I will
likely reply to "tech-talk-bounces". You'd have to edit the recipient
to avoid that.
No.
Tech-Talk messages are keeping the original sender in the "From:" header intact, so a simple "reply" should create a mail to the original sender.
The "tech-talk-bounces" address is added in the "Sender:" and - more importantly - "Errors-To:" headers to direct mail bounces to mailman's automated bounce-handling mechanism.
This fully complies to the relevant RFCs and works without any problem on most mail clients and with ten-thousands of lists that are handled by mailman world-wide.
What mail client are you using that shows this erroneous behavior?
Cheers,
Ralph
Re: Please do not hijack threads [was: cPCI] Maren Purves
Time stamp question Andrew Wagner
cPCI leige
Please do not hijack threads [was: cPCI] Ben Franksen
Re: Please do not hijack threads [was: cPCI] Andrew Johnson
Prev: Re: Please do not hijack threads [was: cPCI] Maren Purves
Next: RE: Camera Link drivers for areaDetector? Timothy Madden
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Please do not hijack threads [was: cPCI] Maren Purves
ANJ, 07 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
