1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: msi and scoping
To: [email protected]
Date: Mon, 6 Sep 2010 14:29:43 +0200
As I discovered today, msi does not handle scoping as I thought it would
(and think it should). What msi (both msi-1.5 and my extended version) does
is to open a scope for each
  file <filename> { }
block. But *not* for each instance inside such a block, i.e. in
  file xyz {
    { X=1, Y=a }
    { X=2 }
in the second substitution instance  Y=a  is still defined.
This is easily fixed by moving the calls to macPushScope and macPopScope
inside the inner while loop. The following patch is relative to my latest
version:
diff -rN -u old-msi/msi.c new-msi/msi.c
--- old-msi/msi.c       2010-09-06 13:53:50.687470977 +0200
+++ new-msi/msi.c       2010-09-06 13:53:50.687470977 +0200
@@ -125,12 +125,12 @@
                    fprintf(stderr,"no template file\n");
                    usageExit();
-                if (optScoped) macPushScope(macPvt);
                while((pval = substituteGetReplacements(substitutePvt))){
+                    if (optScoped) macPushScope(macPvt);
                    addMacroReplacements(macPvt,pval);
                    makeSubstitutions(inputPvt,macPvt,filename);
+                    if (optScoped) macPopScope(macPvt);
-                if (optScoped) macPopScope(macPvt);
         } while (isGlobal || isFile);
         substituteDestruct(substitutePvt);
while this one is relative to msi-1.5:
diff -rN -u old-1-5/msi.c new-1-5/msi.c
--- old-1-5/msi.c       2010-09-06 13:59:11.819132417 +0200
+++ new-1-5/msi.c       2010-09-06 13:59:11.827129619 +0200
@@ -113,12 +113,12 @@
                usageExit();
-            macPushScope(macPvt);
+                macPushScope(macPvt);
+                macPopScope(macPvt);
-            macPopScope(macPvt);
Cheers
Ben
Prev: Build IOC linking external *.lib file failed zhangning2095
Next: RE: Camera Link drivers for areaDetector? fajin.yuan
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Build IOC linking external *.lib file failed Mark Rivers
Next: Examples of synApps scaler record using asyn port driver Angus Gratton
ANJ, 09 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
