Babak,
You can use compress records with waveform records...
The compress record whenever processed buffers all of the INP waveform (only its valid values <NELM)
# Circular buffer
record(compress, "$(compressRecord)") {
field(DESC, "Circular Buffer")
field(SCAN, "Passive")
field(NSAM, "$(numberOfSamplesInCompressRecord)")
field(INP, "$(inputWaveformRecord) NPP NMS")
field(ALG, "Circular Buffer")
Note: Make sure the compress record process only when the INP waveform has been updated entirely otherwise you may buffer the same values twice or more.
Maybe you can FLNK or PP them ...
Emmanuel
On 15:58 Mon 16 Aug , Kalantari Babak wrote:
> For the synchronous data collection of SwissFEL (and its test facility)
> we make intensive use of "compress" record to locally buffer the
> acquired data in high rate at each IOC.
> In addition to single valued PVs (scalars) we need to buffer waveforms
> as well. This is especially interesting for buffering images and LLRF
> data. Before going for any development, I would like to know if anybody
> has worked on something which behaves like "compress" record (at least
> for buffering) but for waveforms (any custom record types, soft device
> supports, etc).
> Any idea is welcome.
> Babak
Emmanuel
- RE: compressArray Kalantari Babak
- compressArray Kalantari Babak
Re: epics site off Andrew Johnson
Re: msi again Linda.Pratt
<2010>
<2010>
