1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: sCalcout - again
To: <[email protected]>
Cc: [email protected]
Date: Tue, 31 Aug 2010 10:29:40 +0100
Pierrick,
You could do a simple numeric calculation in a calc record and send the
output to an mbbi record to give you the string interpretations:
record(calcout,"MICE-ENV-AC-LEAK-04:calStatus") {
        field(DESC,"Water leak status determination")
        field(SCAN,"10 second")
        field(INPA,"MICE-ENV-SECPRB-01:WaterLeakStatus4")
        field(INPB,"MICE-ENV-SECPRB-01:WaterLeakValue4")
        field(CALC,"(A=2||A=4)&&B=0?0:(A=2||A=4)&&B=1?1:2")
        field(OUT,"MICE-ENV-AC-LEAK-04:status PP")
record(mbbi,"MICE-ENV-AC-LEAK-04:status") {
        field(ZRST,"Dry")
        field(ONST,"Leak detected")
        field(TWST,"Error")
-----Original Message-----
[mailto:[email protected]] On Behalf Of Pierrick Hanlet
Sent: 23 August 2010 15:24
To: Kurt Goetze
Subject: Re: sCalcout - again
Hi Kurt,
I'm still having trouble with my db.  This is actually what I have.  The
problem
appears to be in the definition of INAA, INBB, INCC.  When I do a caget
or
camonitor of  MICE-ENV-AC-LEAK-04:calStatus.AA, I find that I have no
value
stored there.  I do see the fields INAA, etc, defined in the dbd file.
The calculation works correctly, as I get the expected 1,0,-1 if I use
the
uncommented CALC line.
record(scalcout,"MICE-ENV-AC-LEAK-04:calStatus") {
        field(INAA,"Dry")
        field(INBB,"Leak detected")
        field(INCC,"Error")
#       field(CALC,"(A=2||A=4)&&B=0?AA:(A=2||A=4)&&B=BB?1:CC")
        field(CALC,"(A=2||A=4)&&B=0?0:(A=2||A=4)&&B=1?1:-1")
        field(SVAL,"MICE-ENV-AC-LEAK-04:Status")
        field(FLNK,"MICE-ENV-AC-LEAK-04:Status.PROC")
#record(stringout,"MICE-ENV-AC-LEAK-04:Status") {
record(ao,"MICE-ENV-AC-LEAK-04:Status") {
        field(DESC,"AC unit water drip status")
        field(SCAN,"Passive")
        field(FLNK,"MICE-ENV-AC-LEAK-01:foStatus.PROC")
Any ideas?  Thanks,
Pierrick
Pierrick Hanlet
Fermilab, P.O. Box 500, M.S. 122
Batavia, IL 60510
[email protected]
(630)840-5555/8871/6039         office/lab/fax
http://www-d0.fnal.gov/~hanlet
"Whether you think you can or think you can't, either way, you are
correct" -- Henry Ford
----- Original Message -----
Date: Wednesday, August 18, 2010 9:26 am
To: Pierrick Hanlet <[email protected]>
> Hi Pierrick,
> I don't see a problem with your conditional expression.  Note that in
> the second example, your desired output will appear in the record's
".SVAL'
> field.
> Kurt
> Pierrick Hanlet wrote:
> > Hello,
> > I don't understand the online documentation regarding the string
> output of sCalcout.  I want to write
> > a string based on the results of a calculation.  Ex:
> > record(scalcout,"myrecord")
> >   field(INPA,"xxx")
> >   field(INPB,"yyy")
> >   field(CALC,"(A=1&&B=0?1:A=0&&B=1?0:-1")
> > What I would really like is
> >   field(INPA,"xxx")
> >   field(INPB,"yyy")
> >   field(INAA,"Good")
> >   field(INBB,"Bad")
> >   field(INCC,"Ugly")
> >   field(CALC,"(A=1&&B=0?AA:A=0&&B=1?BB:CC")
> > What is the correct syntax for affecting this?
> > Thanks in advance,
> > Pierrick
> > Pierrick Hanlet
> > Batavia, IL 60510
> > [email protected]
Scanned by iCritical.
sCalcout Pierrick Hanlet
Re: sCalcout Kurt Goetze
Re: sCalcout - again Pierrick Hanlet
Prev: RE: Windows XP Cygwin cannot find -lCom M . VERDIER
Next: Re: Windows XP Cygwin cannot find -lCom J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: sCalcout - again J. Lewis Muir
Next: Re: sCalcout Tim Mooney
