I change my path from m.verdier to /etc/epics :
- After a MAKE CLEAN and MAKE
- setting SHARED_LIBRARIES=NO and STATIC_BUILD=YES
- HOST_ARCH=win32-x86-cygwin
/usr/lib/gcc/i686-pc-mingw32/3.4.4/../../../../i686-pc-mingw32/bin/ld: cannot find -lCom
collect2: ld returned 1 exit status
make[4]: *** [antelope.exe] Error 1
make[4]: Leaving directory `/etc/epics/src/toolsComm/antelope/O.win32-x86-cygwin'
make[3]: *** [install.win32-x86-cygwin] Error 2
make[3]: Leaving directory `/etc/epics/src/toolsComm/antelope'
make[2]: *** [antelope.install] Error 2
make[2]: Leaving directory `/etc/epics/src/toolsComm'
make[1]: *** [toolsComm.install] Error 2
make[1]: Leaving directory `/etc/epics/src'
make: *** [src.install] Error 2
THEN
- HOST_ARCH=cygwin-x86
/usr/lib/gcc/i686-pc-cygwin/3.4.4/../../../../i686-pc-cygwin/bin/ld: cannot find -lCom
make[4]: Leaving directory `/etc/epics/src/toolsComm/antelope/O.cygwin-x86'
make[3]: *** [install.cygwin-x86] Error 2
Time to leave my working place for today (France).
I will try again tomorrow and I will give you some news.
Cheers
-----"Geoff Savage" a Ãcrit : -----
Subject: Re: Windows XP Cygwin cannot find -lCom
To: [email protected]
Cc: [email protected]
Date: Mon, 30 Aug 2010 09:55:37 -0500
Rebuild everything.
gmake clean
gmake
-----"Mark Rivers" <[email protected]> a Ãcrit : -----
A : <[email protected]>
De : "Mark Rivers" <[email protected]>
Date : 30/08/2010 16:42
cc: "Hu, Yong" <[email protected]>, <[email protected]>
Objet : RE: Windows XP Cygwin cannot find -lCom
I wonder if the problem could be the "." in your path in m.verdier? Try renaming that directory and see if you get the same error.
It should definitely build on cygwin-x86 unless you have the problem with the wrong version of "make".
I believe cygwin-x86 and win32-x86-cygwin are different. The former requires the Cygwin DLL at run time, the latter does not.
Sent: Mon 8/30/2010 9:44 AM
To: Mark Rivers
Cc: Hu, Yong; [email protected]
Subject: RE: Windows XP Cygwin cannot find -lCom
I changed my epics\base\configure\CONFIG_SITE file to set :
SHARED_LIBRARIES=NO
STATIC_BUILD=YES
On Make, The error message is the same.
Then, I kept these parameters and I tried to build it using "HOST_ARCH=cygwin-x86" (after a make clean uinstall) : the lib file "epics\lib\cygwin-x86\Com.lib" has been generated and the message is the same.
make[4]: Leaving directory `/home/m.verdier/epics/src/toolsComm/antelope/O.cygwin-x86'
make[3]: Leaving directory `/home/m.verdier/epics/src/toolsComm/antelope'
make[2]: Leaving directory `/home/m.verdier/epics/src/toolsComm'
make[1]: Leaving directory `/home/m.verdier/epics/src'
Any other idea ???
A : "Hu, Yong" <[email protected]>, <[email protected]>
Date : 30/08/2010 16:19
cc: <[email protected]>
I have not built for HOST_ARCH=win32-x86-cygwin but I have built for HOST_ARCH=cygwin-x86, and there you must use SHARED_LIBRARIES=NO and STATIC_BUILD=YES.
Sent: Mon 8/30/2010 9:09 AM
It seems you have Windows object(static library) 'Com.lib', but you're trying to link 'antelope.exe' with dynamic(shareable) library. Check out the build options 'STATIC_BUILD' and 'SHARED_LIBRARIES' in the configure file /base***/configure/CONFIG_SITE.
Yong
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of [email protected]
Sent: Monday, August 30, 2010 10:01 AM
To: Mark Rivers
The build "Com" library file is located here with the name "Com.lib" :
C:\cygwin\home\m.verdier\epics\lib\win32-x86-cygwin\Com.lib
A : <[email protected]>, <[email protected]>
Date : 30/08/2010 15:41
Did it previously successfully build the "Com" library in this location:
If so, what is the name of the file?
From: [email protected] on behalf of [email protected]
Sent: Mon 8/30/2010 8:01 AM
Subject: Windows XP Cygwin cannot find -lCom
Hello,
I'm beginner in Epics.
I'm trying to build it on Windows XP with Cygwin (HOST_ARCH=win32-x86-cygwin).
I need some help to solve this build error :
make[4]: Entering directory `/home/m.verdier/epics/src/toolsComm/antelope/O.win32-x86-cygwin'
g++ -o antelope.exe -LC:\cygwin\home\m.verdier\epics\lib\win32-x86-cygwin -m32 -mno-cygwin closure.o error.o l
alr.o lr0.o main.o mkpar.o output.o reader.o skeleton.o symtab.o verbose.o warshall.o -lCom
make[4]: Leaving directory `/home/m.verdier/epics/src/toolsComm/antelope/O.win32-x86-cygwin'
Thanks.
Max
- RE: Windows XP Cygwin cannot find -lCom Mark Rivers
- Windows XP Cygwin cannot find -lCom M . VERDIER
- RE: Windows XP Cygwin cannot find -lCom M . VERDIER
- RE: Windows XP Cygwin cannot find -lCom Hu, Yong
Re: msi again Andrew Johnson
<2010>
<2010>
