Rebuild everything.
gmake clean
gmake
On Aug 30, 2010, at 9:44 AM, [email protected] wrote:
I changed my epics\base\configure\CONFIG_SITE file to set :
SHARED_LIBRARIES=NO
STATIC_BUILD=YES
On Make, The error message is the same.
Then, I kept these parameters and I tried to build it using
"HOST_ARCH=cygwin-x86" (after a make clean uinstall) : the lib file
"epics\lib\cygwin-x86\Com.lib" has been generated and the message is
the same.
collect2: ld returned 1 exit status
make[4]: *** [antelope.exe] Error 1
make[4]: Leaving directory `/home/m.verdier/epics/src/toolsComm/
antelope/O.cygwin-x86'
make[3]: *** [install.cygwin-x86] Error 2
make[3]: Leaving directory `/home/m.verdier/epics/src/toolsComm/
antelope'
make[2]: *** [antelope.install] Error 2
make[2]: Leaving directory `/home/m.verdier/epics/src/toolsComm'
make[1]: *** [toolsComm.install] Error 2
make[1]: Leaving directory `/home/m.verdier/epics/src'
make: *** [src.install] Error 2
Any other idea ???
-----"Mark Rivers" <[email protected]> a écrit : -----
A : "Hu, Yong" <[email protected]>, <[email protected]>
De : "Mark Rivers" <[email protected]>
Date : 30/08/2010 16:19
cc: <[email protected]>
Objet : RE: Windows XP Cygwin cannot find -lCom
I have not built for HOST_ARCH=win32-x86-cygwin but I have built for
HOST_ARCH=cygwin-x86, and there you must use SHARED_LIBRARIES=NO and
STATIC_BUILD=YES.
Sent: Mon 8/30/2010 9:09 AM
To: [email protected]
Cc: [email protected]
Subject: RE: Windows XP Cygwin cannot find -lCom
It seems you have Windows object(static library) 'Com.lib', but
you're trying to link 'antelope.exe' with dynamic(shareable)
library. Check out the build options 'STATIC_BUILD' and
'SHARED_LIBRARIES' in the configure file /base***/configure/
CONFIG_SITE.
Yong
-----Original Message-----
] On Behalf Of [email protected]
Sent: Monday, August 30, 2010 10:01 AM
To: Mark Rivers
The build "Com" library file is located here with the name "Com.lib" :
C:\cygwin\home\m.verdier\epics\lib\win32-x86-cygwin\Com.lib
A : <[email protected]>, <[email protected]>
Date : 30/08/2010 15:41
Did it previously successfully build the "Com" library in this
If so, what is the name of the file?
From: [email protected] on behalf of [email protected]
Sent: Mon 8/30/2010 8:01 AM
Subject: Windows XP Cygwin cannot find -lCom
Hello,
I'm beginner in Epics.
I'm trying to build it on Windows XP with Cygwin (HOST_ARCH=win32-
x86-cygwin).
I need some help to solve this build error :
make[4]: Entering directory `/home/m.verdier/epics/src/toolsComm/
antelope/O.win32-x86-cygwin'
g++ -o antelope.exe -LC:\cygwin\home\m.verdier\epics\lib\win32-x86-
cygwin -m32 -mno-cygwin closure.o error.o l
alr.o lr0.o main.o mkpar.o output.o reader.o skeleton.o symtab.o
verbose.o warshall.o -lCom
/usr/lib/gcc/i686-pc-mingw32/3.4.4/../../../../i686-pc-mingw32/bin/
ld: cannot find -lCom
make[3]: *** [install.win32-x86-cygwin] Error 2
antelope'
Thanks.
Max
- Windows XP Cygwin cannot find -lCom M . VERDIER
- RE: Windows XP Cygwin cannot find -lCom Mark Rivers
- RE: Windows XP Cygwin cannot find -lCom M . VERDIER
- RE: Windows XP Cygwin cannot find -lCom Hu, Yong
Re: msi again Andrew Johnson
<2010>
Delta Elektronika PS Ralph Lange
<2010>
