1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: msi again
To: [email protected]
Date: Thu, 26 Aug 2010 16:59:49 +0200
On Mittwoch, 25. August 2010, Andrew Johnson wrote:
> You're right, these should all be valid:
> file xyz { pattern {} }		- No insertion
> file xyz { pattern {} {} }		- Insert xyz
> file xyz { pattern {x} }		- No insertion
> file xyz { pattern {x} {} }		- Insert xyz, x inherits or is undefined
> file xyz { pattern {x} {1} }	- Insert xyz, x=1
> However this should result in a warning message, which I added to
> dbLoadTemplate yesterday:
> file xyz { pattern {} {1} }
I would say this is an error.
More generally speaking, the number of pattern-values should always be equal
to the number of pattern-names. Of course, this goes beyond what we can
specify with a context free grammar, so it must be stated (and checked)
separately.
Cheers
Ben
Re: msi again Andrew Johnson
msi again Benjamin Franksen
Re: msi again Benjamin Franksen
Prev: position available at APS in BCDA group Pete Jemian
Next: Re: dbGetSevr on epics 3.14.11 Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: msi again Andrew Johnson
Next: Re: msi again Andrew Johnson
