1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: GNU make 3.82 problem
To: "Allison, Stephanie" <[email protected]>
Date: Tue, 24 Aug 2010 09:45:11 -0700
FWIW, I was able to build EPICS R3.14.11 for  RTEMS-mvme2100, RTEMS-mvme3100, RTEMS-uC5282 and darwin-x86 using GNU make 3.8.2.
On Aug 23, 2010, at 4:08 PM, Allison, Stephanie wrote:
> Hello,
> Has anybody built epics 3.14.11 using GNU make 3.82?  I had to upgrade my gnu make and got 3.82 but then had problems with the EPICS base build where it tried to install an object library as a shareable library (on both solaris-sparc-gnu and linux-x86).  I went back and got 3.81 instead - it works fine and I'll stick with it.  I see that 3.82 is a very recent release (July 28, 2010).  The software requirements for 3.14.11 say GNU make "3.81 or higher" so perhaps I'm doing something wrong.
> Thank you,
> Stephanie Allison
> [email protected]
Eric Norum
[email protected]
GNU make 3.82 problem Allison, Stephanie
Prev: Re: msi again Benjamin Franksen
Next: Re: error while loading shared library libstdc++.so.5:ARM based SBC Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: GNU make 3.82 problem Allison, Stephanie
Next: error while loading shared library libstdc++.so.5:ARM based SBC tanushyam bhattacharjee
