On Monday 23 August 2010 13:42:21 Till Straumann wrote:
> Nevertheless, if edm used the attributes it still should see a change in
> e.g., display limit the next time the value updates.
Using DBR_GR_XXX with value monitors could place a fair burden on the IOC though. Filling in a dbr_gr_double structure for instance requires the IOC to call the record type's get_units(), get_precision(), get_graphic_double() and get_alarm_double() routines, and the calling tree to get to them from the db_get_field() that rsrv calls is several levels deep in some cases.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
- RE: edm meter Jeff Hill
- edm meter Wesley Moore
- Re: edm meter Andrew Johnson
- Re: edm meter Till Straumann
Re: edm meter Wesley Moore
<2010>
<2010>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
