1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: edm meter
To: Wesley Moore <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Mon, 23 Aug 2010 12:50:21 -0500
Hi Wesley,
I've not tried this, but it ought to work in principle.
Make two meters and have one visible for one range and the other visible for the other
range.
Pierrick
Pierrick Hanlet
Fermilab, P.O. Box 500, M.S. 122
Batavia, IL 60510
[email protected]
(630)840-5555/8871/6039         office/lab/fax
http://www-d0.fnal.gov/~hanlet
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
----- Original Message -----
Date: Monday, August 23, 2010 11:59 am
Subject: edm meter
To: EPICS Tech-Talk <[email protected]>
> EDM users/knowledgeable,
> I like that a meter can use HOPR and LOPR for setting it's scale.  Is
> there a way to update the meter when HOPR/LOPR change without having
> to
> reopen the screen?  My interest is for a power meter that has
> different
> scales so I want the edm meter to update accordingly.
> Thanks,
> Wesley
edm meter Wesley Moore
Prev: Re: edm meter Till Straumann
Next: Re: edm meter Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: edm meter Jeff Hill
Next: Re: edm meter John William Sinclair
