I've had the same problem.
IIRC there are some widgets that use or could use information
which is available via DBR_GR_xxx CA transfers but which
do not properly track changes of the data attributes (such as units or
limits).
It looks like these attributes are only fetched when a connection is
created and then cached by EDM.
FWIW
- Till
On 08/23/2010 11:57 AM, Wesley Moore wrote:
EDM users/knowledgeable,
I like that a meter can use HOPR and LOPR for setting it's scale. Is
there a way to update the meter when HOPR/LOPR change without having
to reopen the screen? My interest is for a power meter that has
different scales so I want the edm meter to update accordingly.
Wesley
- Re: edm meter Andrew Johnson
- edm meter Wesley Moore
Re: edm meter Pierrick Hanlet
<2010>
<2010>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
