Sorry for replying to myself, but I found that the restriction that global
substitution sets must precede file substitution sets is too, well,
restrictive. In fact, I found a place where we use the /dev/null trick twice
in two separate locations in the same substitution files.
I have attached a new version of msi.c that allows mixing file and global
sections. The semantics is that definitions inside a global section are
valid from the point of definition to the rest of the file, except where
overwritten by other global definitions or shadowed by local ones (in file
sections).
(Also attached is a patch relative to the last version I sent.)
Cheers
Ben
Hahn-Meitner-Platz 1, 14109 Berlin
Vorsitzende des Aufsichtsrates: Prof. Dr. Dr. h.c. mult. Joachim Treusch
Stellvertretende Vorsitzende: Dr. Beatrix Vierkorn-Rudolph Geschäftsführer: Prof. Dr. Anke Rita Kaysser-Pyzalla, Prof. Dr. Dr. h.c. Wolfgang Eberhardt, Dr. Ulrich Breuer
Sitz der Gesellschaft: Berlin Handelsregister: AG Charlottenburg, 89 HRB 5583
Disclaimer automatically attached by the E-Mail Security Appliance
mail0.bessy.de 08/23/10 at Helmholtz-Zentrum Berlin GmbH.
* Copyright (c) 2002 The University of Chicago, as Operator of Argonne
* National Laboratory.
* Copyright (c) 2002 The Regents of the University of California, as
* Operator of Los Alamos National Laboratory.
* This file is distributed subject to a Software License Agreement found
* in the file LICENSE that is included with this distribution.
/*msi - macro sunstitutions and include */
* Modification Log:
* .01 08DEC97 mrk Original version
#include <stdlib.h>
#include <stddef.h>
#include <stdio.h>
#include <string.h>
#include <ctype.h>
#include <errno.h>
#include <dbDefs.h>
#include <macLib.h>
#include <ellLib.h>
#define MAX_BUFFER_SIZE 4096
#if ((EPICS_VERSION <= 3) && (EPICS_REVISION <= 13))
#define macEnvExpand(x) strdup(x)
#endif
/*Forward references to local routines*/
static void usageExit(void);
static void addMacroReplacements(MAC_HANDLE *macPvt,char *pval);
static void makeSubstitutions(void *inputPvt,void *macPvt,char *templateName);
/*Routines that read the template files */
static void inputConstruct(void **inputPvt);
static void inputDestruct(void *inputPvt);
static void inputAddPath(void *inputPvt, char *pval);
static void inputBegin(void *inputPvt,char *fileName);
static char *inputNextLine(void *inputPvt);
static void inputNewIncludeFile(void *inputPvt,char *name);
static void inputErrPrint(void *inputPvt);
/*Routines that read the substitution file */
static void substituteDestruct(void *substitutePvt);
static void substituteOpen(void **substitutePvt,char *substitutionName);
static int substituteGetNextSet(void *substitutePvt,char **filename);
static int substituteGetGlobalSet(void *substitutePvt);
static char *substituteGetReplacements(void *substitutePvt);
/*Exit status*/
static int exitStatus = 0;
int main(int argc,char **argv)
void *inputPvt;
MAC_HANDLE *macPvt;
char *pval;
int narg;
char *substitutionName=0;
char *templateName=0;
int i;
int optScoped=0;
inputConstruct(&inputPvt);
macCreateHandle(&macPvt,0);
macSuppressWarning(macPvt,1);
while((argc>1) && (argv[1][0] == '-')) {
narg = (strlen(argv[1])==2) ? 2 : 1;
pval = (narg==1) ? (argv[1]+2) : argv[2];
if(strncmp(argv[1],"-I",2)==0) {
inputAddPath(inputPvt,pval);
} else if(strncmp(argv[1],"-o",2)==0) {
if(freopen(pval,"w",stdout)==NULL) {
fprintf(stderr,"Can't open %s for writing: %s\n", pval, strerror(errno));
exit(1);
} else if(strncmp(argv[1],"-M",2)==0) {
addMacroReplacements(macPvt,pval);
} else if(strncmp(argv[1],"-S",2)==0) {
substitutionName = calloc(strlen(pval)+1,sizeof(char));
strcpy(substitutionName,pval);
} else if(strncmp(argv[1],"-V",2)==0) {
macSuppressWarning(macPvt,0);
narg = 1; /* no argument for this option */
} else if(strncmp(argv[1],"-c",2)==0) {
optScoped = 1;
} else {
usageExit();
argc -= narg;
for(i=1; i<argc; i++) argv[i] = argv[i + narg];
if(argc>2) {
fprintf(stderr,"too many filename arguments\n");
usageExit();
if(argc==2) {
templateName = calloc(strlen(argv[1])+1,sizeof(char));
strcpy(templateName,argv[1]);
if(!substitutionName) {
makeSubstitutions(inputPvt,macPvt,templateName);
} else {
void *substitutePvt;
char *filename = 0;
int isGlobal, isFile;
substituteOpen(&substitutePvt,substitutionName);
do {
if ((isGlobal = substituteGetGlobalSet(substitutePvt))) {
pval = substituteGetReplacements(substitutePvt);
if(pval) {
} else if ((isFile = substituteGetNextSet(substitutePvt,&filename))) {
if(templateName) filename = templateName;
if(!filename) {
fprintf(stderr,"no template file\n");
usageExit();
if (optScoped) macPushScope(macPvt);
while((pval = substituteGetReplacements(substitutePvt))){
makeSubstitutions(inputPvt,macPvt,filename);
if (optScoped) macPopScope(macPvt);
} while (isGlobal || isFile);
substituteDestruct(substitutePvt);
inputDestruct(inputPvt);
free((void *)templateName);
free((void *)substitutionName);
return(exitStatus);
fprintf(stderr,"usage: msi [options] template\n");
fprintf(stderr,"stdin is used if neither template nor substitution file is given\n");
fprintf(stderr,"options:\n");
fprintf(stderr," -V don't suppress warnings\n");
fprintf(stderr," -o<DIR> place output file in directory <DIR> (default is '.')\n");
fprintf(stderr," -I<DIR> add <DIR> to include file search path\n");
fprintf(stderr," -M<SUBST> add <SUBST> to (global) macro definitions\n");
fprintf(stderr," (<SUBST> is of the form VAR=VALUE,...)\n");
fprintf(stderr," -S<PATH> expand a substitution file\n");
fprintf(stderr," -c macro definitions are scoped (in substitution files)\n");
exit(1);
char **pairs;
long status;
status = macParseDefns(macPvt,pval,&pairs);
if(status==-1) {
fprintf(stderr,"Error macParseDefns error\n");
usageExit();
if(status) {
status = macInstallMacros(macPvt,pairs);
if(!status) {
fprintf(stderr,"Error macInstallMacros error\n");
usageExit();
free((void *)pairs);
typedef enum {cmdInclude,cmdSubstitute} cmdType;
static const char *cmdNames[] = {"include","substitute"};
char *input;
static char buffer[MAX_BUFFER_SIZE];
int n;
static int unexpWarned = 0;
inputBegin(inputPvt,templateName);
while((input = inputNextLine(inputPvt))) {
int expand=1;
char *p;
char *command = 0;
p = input;
/*skip whitespace at beginning of line*/
while(*p && (isspace(*p))) ++p;
/*Look for i or s */
if(*p && (*p=='i' || *p=='s')) command = p;
if(command) {
char *pstart;
char *pend;
char *copy;
int cmdind=-1;
int i;
for(i=0; i< NELEMENTS(cmdNames); i++) {
if(strstr(command,cmdNames[i])) {
cmdind = i;
if(cmdind<0) goto endif;
p = command + strlen(cmdNames[cmdind]);
/*skip whitespace after command*/
/*Next character must be quote*/
if((*p==0) || (*p!='"')) goto endif;
pstart = ++p;
/*Look for end quote*/
while(*p && (*p!='"')) {
/*allow escape for imbeded quote*/
if((*p=='\\') && *(p+1)=='"') {
p += 2; continue;
} else {
if(*p=='"') break;
++p;
pend = p;
if(*p==0) goto endif;
/*skip quote and any trailing blanks*/
while(*++p==' ') ;
if(*p != '\n' && *p !=0) goto endif;
copy = calloc(pend-pstart+1,sizeof(char));
strncpy(copy,pstart,pend-pstart);
switch(cmdind) {
case cmdInclude:
inputNewIncludeFile(inputPvt,copy);
break;
case cmdSubstitute:
addMacroReplacements(macPvt,copy);
break;
default:
fprintf(stderr,"Logic Error: makeSubstitutions\n");
inputErrPrint(inputPvt);
exit(1);
free(copy);
expand = 0;
endif:
if (expand) {
n = macExpandString(macPvt,input,buffer,MAX_BUFFER_SIZE-1);
fputs(buffer,stdout);
if (!unexpWarned && n<0) {
fprintf(stderr,"Warning: unexpanded macros in ouput\n");
unexpWarned++;
typedef struct inputFile{
ELLNODE node;
char *filename;
FILE *fp;
int lineNum;
}inputFile;
typedef struct pathNode {
ELLNODE node;
char *directory;
} pathNode;
typedef struct inputData {
ELLLIST inputFileList;
ELLLIST pathList;
char inputBuffer[MAX_BUFFER_SIZE];
}inputData;
static void inputOpenFile(inputData *pinputData,char *filename);
static void inputCloseFile(inputData *pinputData);
static void inputCloseAllFiles(inputData *pinputData);
static void inputConstruct(void **ppvt)
inputData *pinputData;
pinputData = calloc(1,sizeof(inputData));
ellInit(&pinputData->inputFileList);
ellInit(&pinputData->pathList);
*ppvt = pinputData;
static void inputDestruct(void *pvt)
inputData *pinputData = (inputData *)pvt;
pathNode *ppathNode;
inputCloseAllFiles(pinputData);
while((ppathNode = (pathNode *)ellFirst(&pinputData->pathList))) {
ellDelete(&pinputData->pathList,&ppathNode->node);
free((void *)ppathNode->directory);
free((void *)ppathNode);
free(pvt);
static void inputAddPath(void *pvt, char *path)
ELLLIST *ppathList = &pinputData->pathList;
const char *pcolon;
const char *pdir;
int len;
int emptyName;
pdir = path;
/*an empty name at beginning, middle, or end means current directory*/
while(pdir && *pdir) {
emptyName = ((*pdir == ':') ? 1 : 0);
if(emptyName) ++pdir;
ppathNode = (pathNode *)calloc(1,sizeof(pathNode));
ellAdd(ppathList,&ppathNode->node);
if(!emptyName) {
pcolon = strchr(pdir,':');
len = (pcolon ? (pcolon - pdir) : strlen(pdir));
if(len>0) {
ppathNode->directory = (char *)calloc(len+1,sizeof(char));
strncpy(ppathNode->directory,pdir,len);
pdir = pcolon;
/*unless at end skip past first colon*/
if(pdir && *(pdir+1)!=0) ++pdir;
} else { /*must have been trailing : */
emptyName=1;
if(emptyName) {
ppathNode->directory = (char *)calloc(2,sizeof(char));
strcpy(ppathNode->directory,".");
return;
static void inputBegin(void *pvt,char *fileName)
inputOpenFile(pinputData,fileName);
static char *inputNextLine(void *pvt)
inputFile *pinputFile;
char *pline;
while((pinputFile = (inputFile *)ellFirst(&pinputData->inputFileList))) {
pline = fgets(pinputData->inputBuffer,MAX_BUFFER_SIZE,pinputFile->fp);
if(pline) {
++pinputFile->lineNum;
return(pline);
inputCloseFile(pinputData);
return(0);
static void inputNewIncludeFile(void *pvt,char *name)
inputOpenFile(pinputData,name);
static void inputErrPrint(void *pvt)
fprintf(stderr,"input: %s which is ",pinputData->inputBuffer);
pinputFile = (inputFile *)ellFirst(&pinputData->inputFileList);
while(pinputFile) {
fprintf(stderr,"line %d of ",pinputFile->lineNum);
if(pinputFile->filename) {
fprintf(stderr," file %s\n",pinputFile->filename);
} else {
fprintf(stderr,"stdin:\n");
pinputFile = (inputFile *)ellNext(&pinputFile->node);
if(pinputFile) {
fprintf(stderr," which is included from ");
} else {
fprintf(stderr,"\n");
pathNode *ppathNode = 0;
char *fullname = 0;
FILE *fp = 0;
if(!filename) {
fp = stdin;
} else if((ellCount(ppathList)==0) || strchr(filename,'/')){
fp = fopen(filename,"r");
} else {
ppathNode = (pathNode *)ellFirst(ppathList);
while(ppathNode) {
fullname = calloc(strlen(filename)+strlen(ppathNode->directory) +2,
sizeof(char));
strcpy(fullname,ppathNode->directory);
strcat(fullname,"/");
strcat(fullname,filename);
fp = fopen(fullname,"r");
if(fp) break;
free((void *)fullname);
ppathNode = (pathNode *)ellNext(&ppathNode->node);
if(!fp) {
fprintf(stderr,"Could not open %s\n",filename);
inputErrPrint((void *)pinputData);
exit(1);
pinputFile = calloc(1,sizeof(inputFile));
if(ppathNode) {
pinputFile->filename = calloc(1,strlen(fullname)+1);
strcpy(pinputFile->filename,fullname);
} else if(filename) {
pinputFile->filename = calloc(1,strlen(filename)+1);
strcpy(pinputFile->filename,filename);
} else {
pinputFile->filename = calloc(1,strlen("stdin")+1);
strcpy(pinputFile->filename,"stdin");
pinputFile->fp = fp;
ellInsert(&pinputData->inputFileList,0,&pinputFile->node);
if(!pinputFile) return;
ellDelete(&pinputData->inputFileList,&pinputFile->node);
if(fclose(pinputFile->fp))
fprintf(stderr,"fclose failed: file %s\n",pinputFile->filename);
free(pinputFile->filename);
free(pinputFile);
while((pinputFile=(inputFile *)ellFirst(&pinputData->inputFileList))){
/*start of code that handles substitution file*/
typedef enum {
tokenLBrace,tokenRBrace,tokenSeparater,tokenString,tokenEOF
}tokenType;
typedef struct subFile {
char *substitutionName;
FILE *fp;
int lineNum;
char *pnextChar;
tokenType token;
char string[MAX_BUFFER_SIZE];
} subFile;
typedef struct patternNode {
ELLNODE node;
char *var;
}patternNode;
typedef struct subInfo {
subFile *psubFile;
int isFile;
char *filename;
int isPattern;
ELLLIST patternList;
size_t size;
size_t curLength;
char *macroReplacements;
}subInfo;
static char *subGetNextLine(subFile *psubFile);
static tokenType subGetNextToken(subFile *psubFile);
static void subFileErrPrint(subFile *psubFile,char * message);
static void freeSubFile(subInfo *psubInfo);
static void freePattern(subInfo *psubInfo);
static void catMacroReplacements(subInfo *psubInfo,const char *value);
subFile *psubFile = psubInfo->psubFile;
if(psubFile->fp) {
if(fclose(psubFile->fp))
fprintf(stderr,"fclose failed on substitution file\n");
free((void *)psubFile);
free((void *)psubInfo->filename);
psubInfo->psubFile = 0;
patternNode *ppatternNode;
while((ppatternNode = (patternNode *)ellFirst(&psubInfo->patternList))) {
ellDelete(&psubInfo->patternList,&ppatternNode->node);
free(ppatternNode->var);
free(ppatternNode);
psubInfo->isPattern = 0;
static void substituteDestruct(void *pvt)
subInfo *psubInfo = (subInfo *)pvt;
freeSubFile(psubInfo);
freePattern(psubInfo);
free((void *)psubInfo);
return;
static void substituteOpen(void **ppvt,char *substitutionName)
subInfo *psubInfo;
subFile *psubFile;
FILE *fp;
psubInfo = calloc(1,sizeof(subInfo));
*ppvt = (void *)psubInfo;
psubFile = calloc(1,sizeof(subFile));
psubInfo->psubFile = psubFile;
ellInit(&psubInfo->patternList);
fp = fopen(substitutionName,"r");
if(!fp) {
fprintf(stderr,"Could not open %s\n",substitutionName);
exit(1);
psubFile->substitutionName = substitutionName;
psubFile->fp = fp;
psubFile->lineNum = 0;
psubFile->inputBuffer[0] = 0;
psubFile->pnextChar = &psubFile->inputBuffer[0];
subGetNextToken(psubFile);
return;
static int substituteGetGlobalSet(void *pvt)
while(psubFile->token==tokenSeparater) subGetNextToken(psubFile);
if(psubFile->token==tokenString && strcmp(psubFile->string,"global")==0) {
return(1);
return(0);
static int substituteGetNextSet(void *pvt,char **filename)
*filename = 0;
if(psubFile->token==tokenEOF) return(0);
if(psubFile->token==tokenString && strcmp(psubFile->string,"file")==0) {
psubInfo->isFile = 1;
if(subGetNextToken(psubFile)!=tokenString) {
subFileErrPrint(psubFile,"Expecting filename");
exit(1);
if(psubFile->string[0]=='"'&&psubFile->string[strlen(psubFile->string)-1]=='"') {
psubFile->string[strlen(psubFile->string)-1]='\0';
psubInfo->filename = macEnvExpand(psubFile->string+1);
else {
psubInfo->filename = macEnvExpand(psubFile->string);
while(subGetNextToken(psubFile)==tokenSeparater);
if(psubFile->token!=tokenLBrace) {
subFileErrPrint(psubFile,"Expecting {");
exit(1);
*filename = psubInfo->filename;
if(psubFile->token==tokenLBrace) return(1);
if(psubFile->token==tokenRBrace) return(1);
if(psubFile->token!=tokenString
|| strcmp(psubFile->string,"pattern")!=0) {
subFileErrPrint(psubFile,"Expecting pattern");
exit(1);
psubInfo->isPattern = 1;
exit(1);
while(1) {
if(psubFile->token!=tokenString) break;
ppatternNode = calloc(1,sizeof(patternNode));
ellAdd(&psubInfo->patternList,&ppatternNode->node);
ppatternNode->var = calloc(strlen(psubFile->string)+1,sizeof(char));
strcpy(ppatternNode->var,psubFile->string);
if(psubFile->token!=tokenRBrace) {
subFileErrPrint(psubFile,"Expecting }");
exit(1);
return(1);
static char *substituteGetReplacements(void *pvt)
if(psubInfo->macroReplacements) psubInfo->macroReplacements[0] = 0;
psubInfo->curLength = 0;
if(psubFile->token==tokenRBrace && psubInfo->isFile) {
psubInfo->isFile = 0;
psubInfo->filename = 0;
return(0);
if(psubFile->token!=tokenLBrace) return(0);
if(psubInfo->isPattern) {
int gotFirstPattern = 0;
ppatternNode = (patternNode *)ellFirst(&psubInfo->patternList);
while(1) {
if(psubFile->token==tokenRBrace) {
if(ppatternNode)
subFileErrPrint(psubFile,"less values than patterns");
return(psubInfo->macroReplacements);
if(psubFile->token!=tokenString) {
subFileErrPrint(psubFile,"Illegal token");
exit(-1);
if(gotFirstPattern) catMacroReplacements(psubInfo,",");
gotFirstPattern = 1;
if(ppatternNode) {
catMacroReplacements(psubInfo,ppatternNode->var);
catMacroReplacements(psubInfo,"=");
catMacroReplacements(psubInfo,psubFile->string);
ppatternNode = (patternNode *)ellNext(&ppatternNode->node);
} else {
subFileErrPrint(psubFile,"more values than patterns");
} else while(1) {
switch(subGetNextToken(psubFile)) {
case tokenRBrace:
if (!psubInfo->macroReplacements) {
catMacroReplacements(psubInfo,"");
case tokenSeparater:
break;
case tokenString:
break;
default:
exit(1);
char *pline;
do {
pline = fgets(psubFile->inputBuffer,MAX_BUFFER_SIZE,psubFile->fp);
++psubFile->lineNum;
} while(pline && psubFile->inputBuffer[0]=='#');
if(!pline) {
psubFile->token = tokenEOF;
psubFile->pnextChar = 0;
return(0);
return(&psubFile->inputBuffer[0]);
fprintf(stderr,"substitution file %s line %d: %s",
psubFile->substitutionName,
psubFile->lineNum,psubFile->inputBuffer);
fprintf(stderr,"%s\n",message);
char *p;
char *pto;
p = psubFile->pnextChar;
if(!p) { psubFile->token = tokenEOF; return(tokenEOF);}
if(*p==0 || *p=='\n' || *p=='#') {
p = subGetNextLine(psubFile);
else { psubFile->token = tokenSeparater; return(tokenSeparater);}
while(isspace(*p)) p++;
if(*p=='{') {
psubFile->token = tokenLBrace;
psubFile->pnextChar = ++p;
return(tokenLBrace);
if(*p=='}') {
psubFile->token = tokenRBrace;
return(tokenRBrace);
if(*p==0 || isspace(*p) || *p==',') {
while(isspace(*p) || *p==',') p++;
psubFile->pnextChar = p;
/*now handle quoted strings*/
if(*p=='"') {
pto = &psubFile->string[0];
*pto++ = *p++;
while(*p!='"') {
if(*p==0 || *p=='\n') {
subFileErrPrint(psubFile,"Strings must be on single line\n");
exit(1);
*pto++ = *p++;
*pto++ = *p++;
continue;
*pto++ = *p++;
*pto++ = *p++;
*pto = 0;
psubFile->token = tokenString;
return(tokenString);
/*Now take anything up to next non String token and not space*/
while(!isspace(*p) && (strspn(p,"\",{}")==0)) *pto++ = *p++;
*pto = 0;
size_t len = strlen(value);
if(psubInfo->size <= (psubInfo->curLength + len)) {
size_t newsize = psubInfo->size + MAX_BUFFER_SIZE;
char *newbuf;
if(newsize <= psubInfo->curLength + len)
newsize = psubInfo->curLength + len + 1;
newbuf = calloc(1,newsize);
if(!newbuf) {
fprintf(stderr,"calloc failed for size %Zu\n",newsize);
exit(1);
if(psubInfo->macroReplacements) {
memcpy(newbuf,psubInfo->macroReplacements,psubInfo->curLength);
free(psubInfo->macroReplacements);
psubInfo->size = newsize;
psubInfo->macroReplacements = newbuf;
strcat(psubInfo->macroReplacements,value);
psubInfo->curLength += len;
Mon Aug 23 14:10:38 CEST 2010 [email protected]
* allow global substitution sets anywhere at the top level
diff -rN -u old-msi/msi.c new-msi/msi.c
--- old-msi/msi.c 2010-08-23 14:26:46.112050429 +0200
+++ new-msi/msi.c 2010-08-23 14:26:46.116051044 +0200
@@ -110,27 +110,29 @@
} else {
char *filename = 0;
+ int isGlobal, isFile;
- while(substituteGetGlobalSet(substitutePvt)) {
- pval = substituteGetReplacements(substitutePvt);
- if(pval) {
- addMacroReplacements(macPvt,pval);
- while(substituteGetNextSet(substitutePvt,&filename)) {
- if(templateName) filename = templateName;
- if(!filename) {
- fprintf(stderr,"no template file\n");
- usageExit();
+ do {
+ if ((isGlobal = substituteGetGlobalSet(substitutePvt))) {
+ pval = substituteGetReplacements(substitutePvt);
+ if(pval) {
+ addMacroReplacements(macPvt,pval);
+ } else if ((isFile = substituteGetNextSet(substitutePvt,&filename))) {
+ if(templateName) filename = templateName;
+ if(!filename) {
+ fprintf(stderr,"no template file\n");
+ usageExit();
+ if (optScoped) macPushScope(macPvt);
+ while((pval = substituteGetReplacements(substitutePvt))){
+ makeSubstitutions(inputPvt,macPvt,filename);
+ if (optScoped) macPopScope(macPvt);
- if (optScoped) macPushScope(macPvt);
- while((pval = substituteGetReplacements(substitutePvt))){
- makeSubstitutions(inputPvt,macPvt,filename);
- if (optScoped) macPopScope(macPvt);
+ } while (isGlobal || isFile);
- Re: msi again Andrew Johnson
- msi again Benjamin Franksen
- Re: msi again Benjamin Franksen
Re: Asyn and I/O intr scanning Hinko Kocevar
RE: Asyn and I/O intr scanning Mark Rivers
<2010>
<2010>
