1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: sCalcout
To: Pierrick Hanlet <[email protected]>
Date: Wed, 18 Aug 2010 09:26:49 -0500
Hi Pierrick,
I don't see a problem with your conditional expression.  Note that in
the second example, your desired output will appear in the record's ".SVAL'
field.
Kurt
Pierrick Hanlet wrote:
Hello,
I don't understand the online documentation regarding the string output of sCalcout.  I want to write
a string based on the results of a calculation.  Ex:
record(scalcout,"myrecord")
  field(INPA,"xxx")
  field(INPB,"yyy")
  field(CALC,"(A=1&&B=0?1:A=0&&B=1?0:-1")
What I would really like is field(INPA,"xxx")
field(INPB,"yyy")
field(INAA,"Good")
field(INBB,"Bad")
field(INCC,"Ugly")
field(CALC,"(A=1&&B=0?AA:A=0&&B=1?BB:CC")
What is the correct syntax for affecting this?
Thanks in advance,
Pierrick
Pierrick Hanlet
Fermilab, P.O. Box 500, M.S. 122
Batavia, IL 60510
[email protected]
(630)840-5555/8871/6039 office/lab/fax http://www-d0.fnal.gov/~hanlet
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
Re: sCalcout emmanuel_mayssat
Re: sCalcout - again Pierrick Hanlet
sCalcout Pierrick Hanlet
Prev: Re: Runtime Input Question Ned Arnold
Next: Re: sCalcout Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: sCalcout Pierrick Hanlet
Next: Re: sCalcout emmanuel_mayssat
