Andrew, There's an App for that. [Sorry, I couldn't resist.]
There's a database in the synApps/std module that's intended to add ramping
to any PV. It might be a useful starting point. The database contains
some stuff
you might not want, because it supports redefining the ramp target and
readback
PV's at run time, and restoring those choices after an ioc reboot, but
the basic
ramping stuff might be worth looking at. Also the database addresses the
problem
of telling a ca_put_callback() client when the ramp has arrived at the
commanded
value, which might or might not be useful for you.
You can see a copy of the database here:
https://subversion.xor.aps.anl.gov/synApps/std/trunk/stdApp/Db/ramp_tweak.db
and MEDM display files
https://subversion.xor.aps.anl.gov/synApps/std/trunk/stdApp/op/adl/ramp_tweak.adl
Andrew Wagner wrote:
Hey guys,
I'm building a database to ramp a magnet given inputs from an Agilent 34970 MUX and output to an Agilent 3631 Voltage programmer. I've got the drivers and device support working for the MUX and programmer and would like to create a database (and separate application) that can access the AI and AO records from the devices and and perform calculations. My question is: Do records loaded in the same IOC have access to each others PVs? For instance if I :
dbLoadRecords("db/devAG34970.db",args)
dbLoadRecords("db/devAG3631.db",args)
to load the AI and AO records for the devices, can I have a third record,
dbLoadRecords("db/MagnetCtrl.db",args)
that contains calc records that have inputs from pvs defined in the devAG records? Alternatively, do I have to define one big record that includes everything I want.
Cheers,
Andrew
Tim Mooney ([email protected]) (630)252-5417
Software Services Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
- DataBase question Andrew Wagner
Re: DataBase question Matthieu Bec
some patches for msi Benjamin Franksen
<2010>
<2010>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
