1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Problem with streamDevice and I/O Intr
To: Dirk Zimoch <[email protected]>
Cc: [email protected], Florian Feldbauer <[email protected]>
Date: Thu, 12 Aug 2010 14:10:00 +0200 (CEST)
Hi Dirk,
your guess is correct. The USBCAN maps as /dev/tty on our system.
At the moment I read out my device every 10 seconds.
That means every 10 seconds a bunch of 64 messages are send from the device.
Within such a bunch every 276 us one message is send.
Florian
On Thu, 12 Aug 2010, Dirk Zimoch wrote:
Hi Florian,
I have to set up a test system to find out what's wrong. That might take a while. I guess your USBCAN mapps to a /dev/tty... on your system (like a standard sreial device?).
At which rate do you get these messages?
Dirk
Florian Feldbauer wrote:
Dear Dirk,
 The device is custom hardware. The CAN messages come from a AT90CAN64
 microcontroller with a PCA82C250 CAN transceiver.
 http://www.atmel.com/dyn/resources/prod_documents/doc7679.pdf
 This mircocontroller send one message after another.
 They all look like "t6804NODDDDCH\r" where NO is the channelnumber (0-63),
 DDDD the appropriate 14-bit conversion result from the ADC and CH
 an 8-bit checksum. All coded in hexadecimal
 The baudrate of the CAN bus is set to 1 Mbaud.
Florian
On Tue, 10 Aug 2010, Dirk Zimoch wrote:
> Hi Florian,
> > Looks like a race condition. I have to look in the driver. I fear there > is nothing you can do about it.
> > How does the communication work? You say you get 64 messages in series. > What do they look like? All like "t68043F34AAA1\r" (only difference in > $(no))? That is the timing of these messages? Do they all come in one > burst? Do you have a link to the device documentation?
> > Dirk
> > Hello all,
> > > > I ran into a problem when reading from a serial device using I/O Intr
> > processing with streamDevice. I receive 64 messages in series and have
> > one record for each message.
> > Now and then I get the error message from epics:
> > > > timerQueue INTERNAL ERROR (PANDA:FEMC:PROTO192:THMP:680:CHK:00): > > timerExpired() unexpected ioAction None
> > > > Any idea how to fix this problem?
> > > > This is the db:
> > record (scalcout, "THMP:$(ID):CHK:$(no)")
> > field (DTYP, "stream")
> > field (SCAN, "I/O Intr")
> > field (CALC, "((K XOR L) XOR C)==E?(K<<8)+L:LL")
> > field (OUT, "@THMP.proto getMsg($(no)) USBCAN1")
> > field (INPC, "$(no)")
> > field (INLL, "INV CHK")
> > > > This is the protocol:
> > Terminator = CR;
> > getMsg{
> > in "t6804\${2}%(K)2X%(L)2X%(E)2X";
> > > > This is an example string, which is sent from the device:
> > t68043F34AAA1\r
> > > > Best regards
> > Florian
-- ------------------------------------- | Florian Feldbauer | | Ph.D. student | | | | Institut für Experimentalphysik I | | Ruhr-Universität Bochum | | Universitätsstr. 150 | | D-44780 Bochum | | | | Office: NB 2/172 | | Phone: (+49)234 / 32-23537 | | Fax: (+49)234 / 32-14170 | | Web: http://www.ep1.rub.de | -------------------------------------
Problem with streamDevice and I/O Intr Florian Feldbauer
Re: Problem with streamDevice and I/O Intr Dirk Zimoch
Re: Problem with streamDevice and I/O Intr Florian Feldbauer
Prev: Re: Problem with streamDevice and I/O Intr Dirk Zimoch
Next: Re: devIocStats 3.1.3 released Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: FW: Making a case for cases Steiner, Mathias
