1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: VxWorks and Radius Authentication
Cc: [email protected]
Date: Mon, 9 Aug 2010 10:16:56 -0700
On Aug 5, 2010, at 12:52 PM, Andrew Johnson wrote:
> On Thursday 05 August 2010 14:11:53 Ralph Lange wrote:
>> Why would you let people log into IOCs?
> Speed?  9600 baud is rather slow nowadays.
> Also recent versions of vxWorks 6.x support running multiple target shells at
> the same time, but I should warn anyone who tries this that the EPICS shell
> commands were not written to expect that to be possible, and may have major
> issues with deadlocks or unprotected accesses.  I believe the IOC shell is
> reentrant, but I'm not sure if it's thread-safe.
As far as I know, the IOC shell itself is thread-safe but ,as Andrew points out, the functions that it calls may not be.
> In general therefore I agree with Ralph that using serial consoles is still
> probably a better solution.
Indeed.
Eric Norum
[email protected]
VxWorks and Radius Authentication Gary Carr
Re: VxWorks and Radius Authentication Ralph Lange
Re: VxWorks and Radius Authentication Andrew Johnson
Prev: Re: checkRelease on Windows Andrew Johnson
Next: Re: Problem with streamDevice and I/O Intr Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: VxWorks and Radius Authentication Maren Purves
Next: Re: VxWorks and Radius Authentication Ralph Lange
