Hey guys,
I've got EPICS and ASYN running and have successfully followed one of Eric Norum's examples to talk to an Agilent 34970A MUX (over IP) and store the *IDN in a stringin record. I'm having problems however with reading a voltage measurement back reliably. I create device support with the devGpib template and the commands:
/* Param 0 -- Read identification string */
{&DSET_SI, GPIBREAD, IB_Q_HIGH, "*IDN?\n++read eoi",NULL, 0, 200, NULL, 0, 0, NULL, NULL, NULL},
/*Param 1 -- Read Measurement @ Channel */
{&DSET_AI, GPIBREAD, IB_Q_HIGH, "MEAS:VOLT:DC? (@203)\n++read eoi", NULL, 0, 200, readMEAS, 0, 0, NULL, NULL, NULL}
I'm interfacing with the GPIB device via the PROLOGIX GPIB-Ethernet controller, (Google them, they're pretty neat) so you can ignore the ++read eoi part of the command string. The conversion method is:
static int readMEAS( struct gpibDpvt *pdpvt, int P1, int P2, char **P3){
struct aiRecord *pai= (struct aiRecord *)pdpvt->precord;
double meas;
sscanf(pdpvt->msg,"%lg",&meas);
printf("meas %f\n",meas);
printf("Messge Length %d. Msg %s\n",pdpvt->msgInputLen,pdpvt->msg);
meas = (double)atof(pdpvt->msg);
pai->val = meas;
return 0;
I set:
asynSetTraceMask("L0",-1,0x9)
asynSetTraceIOMask("L0",-1,0x2)
in my st.cmd to do some debugging. When I force one of my voltage measurement records to process the first time I get:
epics> dbtr AG34970:VOLT:Coil
epics> 2010/08/06 15:39:30.848 172.25.100.85:1234 write 32
MEAS:VOLT:DC? (@203)\n++read eoi\n
2010/08/06 15:39:31.011 172.25.100.85:1234 read 17
+2.99865210E+00\n\003
meas 2.998652
Messge Length 15. Msg +2.99865210E+00
meas 2.998652
This is exactly what I expect since I'm supplying the MUX with 3 V at Channel 203. So far so good. When I print the record I get:
epics> dbpr AG34970:VOLT:Coil
ASG: DESC: Coil Voltage DISA: 0 DISP: 0
DISV: 1 NAME: AG34970:VOLT:Coil RVAL: 0
SEVR: INVALID STAT: UDF SVAL: 0 TPRO: 0
VAL: 2.9986521
My first newbie question is why is SEVR: INVALID? The VAL is certainly what I want it to be. The problem occurs if I try to process the record more than once:
epics> 2010/08/06 15:39:49.785 172.25.100.85:1234 write 32
2010/08/06 15:39:49.948 172.25.100.85:1234 read 17
+2.99867890E+00\n\003
meas 0.000000
Messge Length 16. Msg +2.99867890E+00
meas 0.000000
Hmmm........an ASCII string indicating an appropriate value is read but converted into a double of 0.0000 . Note the message length has increased by 1. Its as if a hidden character is appended somewhere that screws up the sscanf and atof functions. Perhaps there is a more error proof way to convert ASCII to doubles? Has anyone seen this before? I have no such problem with my stringin record. I can send *IDN? and read the device name reliably.
Thanks very much for your help. I will happily make any device support I get working public.
Cheers,
Andrew Wagner
- RE: aiRecord/devGpib problem Mark Rivers
- RE: aiRecord/devGpib problem Allison, Stephanie
Re: BOY - XY Graph and macro substitution John William Sinclair
Re: BOY - XY Graph and macro substitution PaweÅ PrÄdki
<2010>
NI USB-6221 BNC Szalata, Zenon M.
<2010>
