1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Making a case for cases
To: EPICS tech-talk <[email protected]>
Date: Fri, 6 Aug 2010 07:18:19 -0500
On Aug 5, 2010, at 5:31 PM, Alan Biocca wrote:
> One thing that is worth considering for new projects is to make a program that builds names. A web based application might be best. So whatever is decided is codified into this one name ratifier.
> Record aliases are of great use also where two naming conventions might meet. For example BPMs and other sensors are of several physical types, but from some views they might not have the same variation in naming as they might from a lower level view.
> -- Alan
Another example of where two naming conventions overlap is when the hardware-oriented engineer want to name a PV based on it's hardware addresses for testing purposes  ...  IOC1:AB1771:C2:S1  ... and the application engineer wants to name that same channel as  LINAC:CAV1:Temperature.  Yes, we have all defined duplicate PVs to implement this (or have one link to the other) but PV aliases is a much more elegant solution.
  Ned
medm Mezger Anton-Chr.
Re: Making a case for cases Steven M. Hartman
Re: Making a case for cases Purcell, J. David
Re: Making a case for cases Andrew Johnson
Re: Making a case for cases Alan Biocca
Prev: BOY - XY Graph and macro substitution PaweÅ PrÄdki
Next: Re: Making a case for cases Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Making a case for cases Alan Biocca
Next: Re: Making a case for cases Pete R. Jemian
