One thing that is worth considering for new projects is to make a program that builds names. A web based application might be best. So whatever is decided is codified into this one name ratifier.
Record aliases are of great use also where two naming conventions might meet. For example BPMs and other sensors are of several physical types, but from some views they might not have the same variation in naming as they might from a lower level view.
-- Alan
On Thu, Aug 5, 2010 at 12:42 PM, Andrew Johnson <[email protected]> wrote:
On Thursday 05 August 2010 14:10:52 Purcell, J. David wrote:
> There are different interpretations that all allow different "valid" names.
> But lack of enforcement also allowed names to also be flat out wrong. And
> now those names are imbedded and we have no real plan on how to fix them.
> In the beginning, if we were told to fix the wrong names, there might have
> been an effort to get to one interpretation of the convention.
Note that since R3.14.11 the IOC supports record aliases, which may provide a
path to fixing wrong names (as long as the right names don't clash with other
wrong names). You would rename the records to the right names and add aliases
for the wrong names that are in use, which allows you to take as long as you
like to fix all the clients that are still using the wrong names; finally you
delete the aliases when they are no longer needed. If you do have name
clashes you can probably still do it, but it might take a few cycles.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
- Re: Making a case for cases Ned Arnold
- medm Mezger Anton-Chr.
- Re: Making a case for cases Steven M. Hartman
- Re: Making a case for cases Purcell, J. David
- Re: Making a case for cases Andrew Johnson
Re: How do I install to $prefix/EPICS/bin, $prefix/EPICS/lib etc.? Andrew Johnson
Re: Making a case for cases Ralph Lange
<2010>
<2010>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
