For the conserver-server, connecting to the soft IOC under procServ
is exactly the same as connecting to a VME IOC connected to a
terminal server - it opens a telnet connection to a port on the
remote host.
If procServ only provides access from localhost, there are two
options:
1. The conserver-server connects opening a ssh connection to the
softIOC host using a key that is configured to call "telnet
localhost nnnn" to connect it to the softIOC. (Or explicitly calling
"telnet localhost nnnn" on the other side.)
2. The softIOC host runs a conserver-server locally, which can
simply run telnet to get to the softIOC.
conserver supports configurations with multiple conserver-servers.
Its client (called console) only needs the IP of one of the
conserver-servers. When console connects, the conserver-server
redirects it to the instance that actually hosts the connection the
clients wants to get to.
So, on any client machine, typing "console <ioc-name>"
connects you to that IOC's console, no matter which conserver-server
hosts the connection, no matter if it is a soft IOC or a VME box.
The main advantages of putting conserver on top are:
- One way to connect to softIOCs and VME IOCs, no configuration on
the client machine (other than the IP of one conserver-server)
- Authentication / Authorization: password-based auth, allows
specifying user groups with different access rights on different
consoles
- One way of logging all console output (with timestamps) to file or
into the syslog protocol
- Replay buffer that can show the console activity before you
connect
- Only one user at a time has write access, all others are
read-only, but users with matching authorization may take over a
console
Ralph
05.08.2010 15:26, Stephen Lewis wrote:
How does conserver fit it with procServ? ÂSeems like
it is harder to use and very centralized. ÂI use procServ and have
a simple shell script that looks up the telnet host/port in a
table by IOC name.
- VxWorks and Radius Authentication Gary Carr
- Re: VxWorks and Radius Authentication Ralph Lange
Re: How do I install to $prefix/EPICS/bin, $prefix/EPICS/lib etc.? Andrew Johnson
Re: How do I install to $prefix/EPICS/bin, $prefix/EPICS/lib etc.? Ralph Lange
<2010>
Re: VxWorks and Radius Authentication Eric Norum
Theweb site for the EPICS October meeting is now open. http://www.bnl.gov/epics/ Dalesio, Leo
<2010>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
