1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: How do I install to $prefix/EPICS/bin, $prefix/EPICS/lib etc.?
To: <[email protected]>
Date: Thu, 05 Aug 2010 15:50:00 -0400
Andrew,
Sorry for the discouraging remark, but setting "INSTALL_LOCATION" didn't
work for me, when I built things for Darwin.
In order to successfully complete the build, I had to create symlinks to the
installed location for the 'bin', 'configure', and 'include' directories.
David Dudley
On 8/5/10 3:06 PM, "Andrew Johnson" <[email protected]> wrote:
> Hi Gary,
> On Thursday 05 August 2010 13:14:04 Gary V. Vaughan wrote:
>> I am in the process of trying to package EPICS base 3.14.11 into
>> native package format on several commercial UNICES, but I can't
>> find a nice way to have it install into a standard tree:
> The EPICS build system isn't going to work with the standard tree that you've
> suggested.  EPICS was designed around the ability to cross-compile for other
> architectures, which is why we install binaries and libraries into an
> architecture-specific subdirectory of <top>/bin and <top>/lib respectively.
> How/where are you going to store the EPICS Base libraries cross-compiled for
> an RTEMS or vxWorks target?  The majority of EPICS sites need to do cross-
> builds like that, and your solution is likely to be less interesting to them
> if you prevent that by changing the installation structure.
>> If I change INSTALL_LOCATION to be anything other than $(TOP)
>> then make fails to find any sources to link, and there don't
>> appear to be any installation rules to relink the libraries
>> and binaries at install time -- nearly all other programs I've
>> packaged provide a 'make install' rule for this purpose.
>> Is there a way to install a runtime EPICS base into the root
>> directory using the existing build system?
> You should be able to set INSTALL_LOCATION inside the configure/CONFIG_SITE
> file before you build base, pointing it to the top directory where you want it
> to make the install tree.  This will ensure that the RPATH entries point to
> the installation tree.  I'm guessing that it might not be possible to set it
> to "/" if that's something that you're having problems with, although I'm not
> sure why it would break.  Note that this also causes the configure directory
> to be copied to $(INSTALL_LOCATION); it's needed by application developers to
> build IOCs against this installation of Base.
> If you want to remove the RPATH entries you're probably better off editing the
> configure/os/CONFIG files to remove the options, although you may find you
> have to set /etc/ld.so.conf so our build tools like flex and antelope are able
> to run.  I believe we've added an option to future releases to allow RPATH to
> be turned off centrally.
> - Andrew
Re: How do I install to $prefix/EPICS/bin, $prefix/EPICS/lib etc.? Gary V. Vaughan
Re: How do I install to $prefix/EPICS/bin, $prefix/EPICS/lib etc.? Andrew Johnson
Prev: Re: Making a case for cases Andrew Johnson
Next: Re: VxWorks and Radius Authentication Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: How do I install to $prefix/EPICS/bin, $prefix/EPICS/lib etc.? Andrew Johnson
Next: Re: How do I install to $prefix/EPICS/bin, $prefix/EPICS/lib etc.? Gary V. Vaughan
