Console access via terminal server is more useful for debugging (as it - other than login - allows access during the boot sequence), and I would consider it safer to just disable remote login completely. (Frees memory on your IOCs, too.) If you put a console access service (such as conserver [1]) on top of the serial line/terminal server connection, you are not on vxWorks anymore, and authenticating against Radius gets a lot easier. Ralph [1] http://conserver.com/ On 05.08.2010 14:54, Gary Carr wrote: Is anyone using a Radius server to provide login authentication for their VxWorks IOCs? I did a search on Tech-Talk, but only saw a reverence to Radius authentication to a terminal server connected to the IOCs.
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
