1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: CSS/BOY macro substitution problem
To: Paweł Prędki <[email protected]>
Date: Thu, 05 Aug 2010 11:03:03 -0400
Hi Pawel,
You can give the default global macros from BOY preference settings, which can be set from menu CSS->Preference->CSS-Applications->Display->BOY. If you set cardno = 0 at here, I think your mainScreen will work as you wanted.
If you don't want to be bothered by Javascript, you can use rules for most of dynamic behavior needs. Please see attachment how the rule can invisble a group widget based on the selection in a combo box.
Xihui
Sent: Thursday, August 05, 2010 10:32 AM
To: Chen, Xihui
Subject: Re: CSS/BOY macro substitution problem
Here you go. Hopefully, it gets through this time.
On 05.08.2010 16:22, Chen, Xihui wrote:
> The attachment is blocked. Could you send them again by compress them in a zip file?
> Thanks,
> Xihui
> From: Paweł Prędki [[email protected]]
> Sent: Thursday, August 05, 2010 10:00 AM
> To: Chen, Xihui
> Hi Xihui,
> Thanks for such a quick answer. Please find the .opi files attached to
> this message.
>> Hi Pawel,
>>> I've started using the CSS ennvironment and BOY for creating GUIs but
>>> I've come across a problem with macro substitution.
>> Thanks for using BOY and ask the questions!
>>> I'm creating a GUI for a data acquisition system which consists of
>>> several DAQ boards. My aim is to have only one XY graph visible at once
>>> on the screen and be able to switch between them using, for example,
>>> action buttons.
>> There may be other options which can make this task easier: using Tab widget or change the pv name of a trace from action button via script.
> I don't really want to use the Tab widget and copy the same setup
> (mainScreen) to all the tabs and changing the names of the PVs connected
> to the widgets. This will require many manual changes if I want to add
> another DAQ card, for example. Macros work perfectly in this case.
> Changing the trace pv name via script could be a good solution but I
> have little experience with JavaScript. On the other hand, I still use
> the macro value in other screens so I would like to keep it.
>>> However, when I specify the macro value for the whole display I am not able to change
>>> it using the action buttons. Somehow, the display macro value definition
>>> trumps the one given by the action button.
>> The macros property cannot be changed via script during runtime. It is only loaded once during opi startup. The display macros will replace the same one from its parents.
>>> The only way I was able to make it work was not specifying any display
>>> macro value. This, however, results in an ugly first screen where all
>>> the controls are disconnected since the macro is undefined. Clicking one
>>> of the action buttons connects to the correct card.
>> Still cannot understand that clearly. Could you send me the opi files?
> When you run the mainScreen.opi the $(cardno) macro is not expanded
> because it is not defined at the global level. Clicking one of the CARD
> buttons replaces the current mainScreen with the same screen but with
> the $(cardno) macro defined. I would like to start the application with,
> for example, cardno=0 and then change it according to the button
> pressed. It was possible in EDM.
> Also, maybe you are able to answer another question. In the GroupConfig
> screen there is a group of controls (Signal Amplitude, Signal Phase)
> that I want to become invisible if one of the options in the nearby
> Combobox is chosen. Is it necessary to use JavaScript to do so? Would
> you be able to give me a hint how to do this?
>> Thanks,
>> Xihui
> Thanks,
> Pawel
Attachment: InvisibleGroupByRule.opi
Description: InvisibleGroupByRule.opi
Re: CSS/BOY macro substitution problem PaweÅ PrÄdki
RE: CSS/BOY macro substitution problem Chen, Xihui
Prev: RE: CSS/BOY macro substitution problem Chen, Xihui
Next: Re: CSS/BOY macro substitution problem PaweÅ PrÄdki
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
