I ran into a problem when reading from a serial device using I/O Intr processing with streamDevice. I receive 64 messages in series and have one record for each message. Now and then I get the error message from epics: timerQueue INTERNAL ERROR (PANDA:FEMC:PROTO192:THMP:680:CHK:00): timerExpired() unexpected ioAction None Any idea how to fix this problem? This is the db: record (scalcout, "THMP:$(ID):CHK:$(no)") { field (DTYP, "stream") field (SCAN, "I/O Intr") field (CALC, "((K XOR L) XOR C)==E?(K<<8)+L:LL") field (OUT, "@THMP.proto getMsg($(no)) USBCAN1") field (INPC, "$(no)") field (INLL, "INV CHK") } This is the protocol: Terminator = CR; getMsg{ in "t6804\${2}%(K)2X%(L)2X%(E)2X"; } This is an example string, which is sent from the device: t68043F34AAA1\r Best regards Florian
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
