1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: archive server discussion
To: [email protected]
Cc: [email protected]
Date: Mon, 2 Aug 2010 11:41:26 -0500
Hi James,
You didn't list my EpicsArchiver -- perhaps  it's not very well known,
but it is used at a few beamlines at the APS.  You can  see it in
action at
   http://millenia.cars.aps.anl.gov/cgi-bin/pvarch/
and there are some documentation and details at
   http://millenia.cars.aps.anl.gov/cgi-bin/pvarch/help.py
I started this many years ago, in the early days of ChannelArchiver I
believe, mostly because I wanted data stored in a relational database.
I don't know much about the other archivers you listed, but I'll give
some details on how the EpicsArchiver works, and what improvements
might be made.   Perhaps the large number of similar implementations
shows how easy it is to do....
I am not a RDMS expert at all, and I'm not sure I can comment much on
using "noSQL" databases.  I do believe that the data is sort of
relational, though the relation is almost always based on time. And,
as you say, the data is being archived, which requires writing the
latest value very quickly, and allowing for complex and relatively
slow lookups.
The implementation for EpicsArchiver uses MySQL on a linux system with
SCSI disks (non-RAID), though I don't think it would be impossible to
switch, to postgresql or Oracle.
Epics Process Variables are monitored and the "latest value" for each
variable is stored in a cache table.  This holds "PV Name, Value,
Timestamp" and not much more.  The table is small, and constantly
updated.    I'm  currently using single-threaded CA,  and a single
process too, but have little difficulty keeping up with ~5000
variables, as most PVs of interest for us move slowly, and only a few
hundred really dominate the access to this cache.   The system I run
has quad-core CPUs, and one of them is essentially dedicated to
running MySQL at 90+% usage.  Again, a multi-threaded/process/cpu
would not be a difficult  upgrade, and could definitely improve
performance for a larger set of variables.
With one process (or one set of threads/process) keeping a cache of
"current values", the actual archiving is fairly easy, and is a
non-EPICS task: it needs only to copy data from one table to archive
tables.   I think this a key feature: it separates fetching a PVs
values from archiving it.    In addition,  "read from the cache" (say
for a status web page) also does not need to be a CA client, and so
can be very fast, as reads from the local disk are much faster than
connecting to and reading with CA for stateless web apps.
For archiving, EpicsArchiver keeps a database with one table of PV
information, and 128 different data tables of PV hashkey, Timestamp,
Value.   That hashing distributes the data, and reduces data lookup
time.  The archiving process just fetches the latest values from the
cache database and decides what to put in the archive database.
I rotate these databases out every month (through a cron job), and
keep one "Master Database" that holds the time-ranges for each of the
databases.    That way, neither look up of "last weeks" data and older
historical data is painfully slow.   The lookup just has to figure out
which databases to look in for a time range, then which table to look
in for a PVs data, and then extract data by PV hashkey and timestamp.
 The EpicsArchiver also includes "Alerts" to send email messages on
user-defined changes in PV status, etc.    It also includes a simple
template system to change what is shown on the status web pages.  It's
all fairly simple database stuff, and very low maintenance.
Cheers,
--Matt Newville <newville at cars.uchicago.edu> 630-252-0431
On Mon, Aug 2, 2010 at 9:59 AM,  <[email protected]> wrote:
> Hi
> At Diamond we are upgrading our archiver hardware, before the EPICS meeting
> I'd like to open the discussion on archive server software. The obvious
> question is: Is there a standard EPICS archiver server suitable for
> everyone? And if not, why not?
> There are a few servers in the community (apologies to their authors if I
> get the details wrong):
> Channel Archiver v1
> index?
> data in file system, files contain per-channel blocks of time-sorted data up
> to 8k samples long
> Channel Archiver v2
> Hashtable + RTree index
> data as above
> CZAR
> Index in RDB
> data storage ?
> compression using arithmetic encoding
> MYA
> RDB replacement for CZAR
> BEAUTY
> Partitioned RDB for index and data
> Hyperarchiver
> RDB for configuration
> Hypertable for index and data (zlib-style compression)
> I only have experience with Channel Archiver v2. Looking at our installation
> archiving 3GB a day, a great deal of time is spent in random write
> operations to the individual data blocks. We buffer for 30 seconds, then
> write approximately 30 samples to each of 30,000 channels. Because of the
> way the data is stored on disk (channel1[8192], channel2[2048],
> channel3[1024] etc.) that's a lot of random writes. The RAID array copes
> well but the large write op load reduces read performance to the point that
> backups and large data-mining jobs are very slow.
> Our typical archiver access pattern is append-only sample writes, read
> channel data from a contiguous time range from up to 100 channels.
> Assuming magnetic disks will store our 10TB+ datasets for the next few
> years, an ideal database would reduce the number of slow random IO
> operations and store data on disk reflecting the typical access pattern. A
> suitable sort key might be (channel, timestamp) or (month, channel,
> timestamp) to partition the data by date. This is the way that hypertable
> and some real-time relational databases get their single-node performance,
> with an in-memory table for recently arrived data, a sequential logfile for
> durability, periodic sorting and flushing of the in-memory table to disk
> in a contiguous write, and period compaction into larger sorted tables.
> The commercial real-time relational databases KDB and Vertica use this
> architecture, if any Oracle or MySQL expert knows if something similar can
> be done with them I'd be very interested. There are alternate storage
> back-ends for MySQL for data warehousing but they only support efficient
> writes in bulk.
> At Diamond we plan to run the v2 archiver with 64 bit index files to allow
> us to merge our indices into one file, and benchmark for performance on some
> updated hardware. I also need to merge the 10TB of data files from a primary
> and standby archive server used for high availability, either by combining
> the data files or adding a merging reader to the storage library. I would
> like to know what other facilities are using and if there are any other
> current archiver developments.
> James
> This e-mail and any attachments may contain confidential, copyright and or
> privileged material, and are for the use of the intended addressee only. If
> you are not the intended addressee or an authorised recipient of the
> addressee please notify us of receipt by returning the e-mail and do not
> use, copy, retain, distribute or disclose the information in or attached to
> the e-mail.
> Any opinions expressed within this e-mail are those of the individual and
> not necessarily of Diamond Light Source Ltd.
> Diamond Light Source Ltd. cannot guarantee that this e-mail or any
> attachments are free from viruses and we cannot accept liability for any
> damage which you may sustain as a result of software viruses which may be
> transmitted in or with the message.
> Diamond Light Source Limited (company no. 4375679). Registered in England
> and Wales with its registered office at Diamond House, Harwell Science and
> Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom
RE: archive server discussion james.rowland
Re: archive server discussion Patrick Thomas
Prev: archive server discussion james.rowland
Next: asyn R4-14 available Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: archive server discussion james.rowland
