1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: HTML Device Driver
To: David Dudley <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 28 Jul 2010 09:58:43 -0700
David Dudley wrote:
Here’s a new one for you (Got Ralph and Michael going about how to do it, anyway ;-)
Almost all of the PLC equipment we’re going to be using on NSLS/2 is connected on Ethernet.
It is common practice in the communications modules now, to integrate an embedded WEB server into the device. Both the Siemens and Rockwell hardware we’re going to use have that capability, as well as most of the new generation of instrumentation.
Does anyone have knowledge of an EPICS device driver that is capable of reading and interpreting a WEB page or XML page? Seems that this would be the most universal way to read data from all this differing equipment, if such a driver was available.
David Dudley
I used StreamDevice + Asyn to acquire data from an ethernet attached instrument containing a built-in web server. It required a minor bit of reverse engineering the HTML code, which was quite simple, and took just a little bit of tutoring from Dirk to get things right. Although the server was not intended for this purpose, the scheme worked well enough.
In the second design iteration of the instrument, they changed the web interface to make it more user friendly. It now uses a Java applet which downloads to the browser, and the applet communicates with the server, or some such stuff that is indecipherable from the standpoint of EPICS support. Given a second lifetime, I might get around to creating EPICS support capable of dealing with that problem. Is an evolving standard like HTML a good thing to rely on for a control system?
Rod Nussbaumer
ISAC Controls, TRIUMF
Vancouver, Canada
HTML Device Driver David Dudley
Prev: RE: Developing of record / driver / device support? Asyn? Mark Rivers
Next: Re: Tech-talk archives excluded from indexing? Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: HTML Device Driver Pete Jemian
Next: Re: HTML Device Driver emmanuel_mayssat
