I do not think the 2D video widget use xpm. The original version
did but the current one does not.
John Sinclair
Kate Feng wrote:
Hi all,
I do not know if anyone still use the libXpm.a library
for X11 applications. Since it is used in the 2D video
widget that I mentioned in the previous thread, I attach
the patch here, which fixes the memory leak that happened
on both our Linux RedHat and Debian PCs. The memory leak
can be detected if the video display is exposed for
some period of time (e.g. not iconized).
I downloaded the source code (ie. xpm-3.4k.tar.gz) for
libXpm.a at ftp://ftp.x.org/contrib/libraries
and applied the attached patch. If XpmReturnAllocPixels
is not specified in the attributes->valuemask, then
(*freeColors)() should be called. I hope this helps.
Cheers,
Kate
diff -u create.c.orig create.c
--- create.c.orig 1998-03-19 14:51:00.000000000 -0500
+++ create.c 2010-05-20 09:42:41.000000000 -0400
@@ -929,8 +929,11 @@
if (attributes && (attributes->valuemask & XpmReturnAllocPixels)) {
attributes->alloc_pixels = alloc_pixels;
attributes->nalloc_pixels = nalloc_pixels;
- } else
- XpmFree(alloc_pixels);
+ } else {
+ /* Kate Feng: feeColors() if alloc'ed pixels is not return.
Otherwise, memory leaks */
+ (*freeColors)(display, colormap, alloc_pixels, nalloc_pixels,
NULL);
+ XpmFree(alloc_pixels);
/* return created images */
if (image_return)
@@ -2234,8 +2237,11 @@
- } else
+ } else {
+ (*freeColors)(display, colormap, alloc_pixels, nalloc_pixels, NULL);
if (image_return)
- Re: A patch for libXpm.a (was Re: edm : TwoDProfileMonitorClass : cropping/resizing image) Kate Feng
- Re: edm : TwoDProfileMonitorClass : cropping/resizing image Kate Feng
- A patch for libXpm.a (was Re: edm : TwoDProfileMonitorClass : cropping/resizing image) Kate Feng
RE: Analog output device support design Mark Rivers
<2010>
<2010>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
