1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: timestamp for change in monitored PV
To: EPICS Tech Talk <[email protected]>
Date: Fri, 23 Jul 2010 23:21:33 -0700
Sorry, I figured it out. However, is there an easy way to report changes only over a certain time period? For example, if a channel can change at 16Hz, to only report the changes in the value every second or every two seconds?
Thank you,
Patrick
Patrick Thomas wrote:
I'm trying to add timestamps to the example caMonitor. Is there a timestamp stored somewhere for each time a PV changes, or do I need to get the current time when the callback is called?
Thank you for your time,
Patrick
Re: timestamp for change in monitored PV Ralph Lange
timestamp for change in monitored PV Patrick Thomas
Prev: timestamp for change in monitored PV Patrick Thomas
Next: Re: timestamp for change in monitored PV Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
