1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Newbie IOC driver/device support problem
To: [email protected]
Date: Fri, 23 Jul 2010 08:59:00 -0400
On 22.07.2010 19:45, Angus Gratton wrote:
On Thu, 2010-07-22 at 09:44 +0200, Burkhard Kolb wrote:
try putting the DTYP line in front of the OUT line in your record.
When OUT is parsed the DTYP is not yet known in your case.
It didn't even dawn on me that database parsing would be order-dependent
like that.
For the record: Won't be much longer.
EPICS Codeathon work by Dirk Zimoch fixing this behavior has been merged into the EPICS 3.14 branch
(see https://code.launchpad.net/~dirk.zimoch/epics-base/DTYP-parsing/+merge/26381)
and thus will be part of the next EPICS Base 3.14 release.
Cheers,
Ralph
Newbie IOC driver/device support problem Angus Gratton
Re: Newbie IOC driver/device support problem Burkhard Kolb
Re: Newbie IOC driver/device support problem Angus Gratton
Prev: Re: Newbie IOC driver/device support problem Luedeke Andreas
Next: Re: copying output of Linux ioc to file Rod Nussbaumer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Build error. GNU make downgrade? Gorka Ronda
