1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: MEDM crash when "Plot Array" of sscan detector with large value
To: [email protected]
Date: Mon, 19 Jul 2010 17:30:50 -0500
Tim,
On Monday 19 July 2010 16:54:46 Tim Mooney wrote:
> Lewis,  Just for completeness, I see this on my system as well.
Are you seeing this on a version of MEDM that is build with XTR/Graph, or with
SciPlot?  Janet's /usr/local/epics/extensions/bin/<arch>/medm binaries are
built with XRT/Graph on Solaris and Linux I believe, and if they show the
problem I think it will increase the pressure for Janet to work on a fix.  We
need to make sure this gets on her list when she gets back (I think she's on
vacation at the moment).
> I could get the sscan record to avoid posting PV's that contain
> NaN's, but I have a lot of other stuff that also gets plotted,
> and that also can post NaN's, so my plan is to sit tight until
> we know whether/when MEDM will be fixed.
It certainly makes sense to fix MEDM rather than try to avoid generating bad
data everywhere.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
Re: MEDM crash when "Plot Array" of sscan detector with large value Tim Mooney
Re: MEDM crash when "Plot Array" of sscan detector with large value J. Lewis Muir
Prev: Re: MEDM crash when "Plot Array" of sscan detector with large value Tim Mooney
Next: Re: MEDM crash when "Plot Array" of sscan detector with large value Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
