1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Epics on ARM linux
To: [email protected], Eric Norum <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Mon, 19 Jul 2010 22:22:18 +0530 (IST)
Dear All,
we did many applications for Strong-ARM using EPICS at our lab and we are changing all iocs to arm based controller by replacing PCs. There
are some changes required to EPICS .ARM is big endian and there is
no direct support on the CPU. It uses floating point simulator instead. The cross compiler on x86 machine can be used during application building and the executable and library(.so and .a) can be copied to target machine.
Best of luck,
Tanushyam Bhattacharjee
Variable Energy Cyclotron Centre,Kolkata,India
Cc: "EPICS tech-talk" <[email protected]>
Date: Saturday, 17 July, 2010, 4:43 AM
We're running EPICS on a SheevaPlug ($99 IOC).
At the APS they're running EPICS on a MOXA UC-7408 Plus
So it's certainly doable.
On Jul 16, 2010, at 4:04 PM, [email protected] wrote:
> I am currently using epics/linux on x86 intel processors.
> Is there any reason why epics/linux wouldn't be supported on arm processors?
> (linux is but any issue to be expected with epics?)
> Is anyone embedding their IOCs in their controlled hardware?
> Emmanuel
Eric Norum
[email protected]
Re: Epics on ARM linux Eric Norum
Prev: Re: Epics on ARM linux Michael Abbott
Next: Re: MEDM crash when "Plot Array" of sscan detector with large value Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Epics on ARM linux Eric Norum
Next: Re: Epics on ARM linux Rod Nussbaumer
