1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: devGpib problem
To: [email protected]
Date: Fri, 16 Jul 2010 13:23:10 -0400
Using VLAN technology (what most larger sites do nowadays), your host-based IOC can define multiple logical interfaces on different VLANs on one physical NIC. This does not require additional hardware and separates the controls (CA) network(s) from the instrument (device) network(s) logically, while still using the same wire.
I would recommend at least this level of separation, as it adds a layer of insulation between the instruments and the wild west on-site network.
People have had bad experiences with stupid network enabled devices (even PLCs) acting weird or crashing caused by things on the network.
Also very useful if you don't want to install all these countless Windows patches on your hi-end scopes (since this breaks them once in a while), but your official IT department policy doesn't allow unpatched Windows systems on visible networks.
Ralph
On Fri 16 Jul 2010 12:24:57 Pete Jemian wrote:
Some parts of APS have these separated but most put them together on the same subnet.
On 07/16/2010 10:58 AM, [email protected] wrote:
On 18:17 Thu 15 Jul , Mark Rivers wrote:
Shifu's device is a TCP/IP power supply, talking a simple ASCII
protocol. When talking to the device it usually responds quickly, but
occasionally the responses are very delayed. Whether this is due to the
device or to the APS network is not clear, but in any event sometimes
the response does not occur until after the 2 second timeout specified
in the devGpib file. However, the device does appear to always
eventually reply.
I have similar problems with a few of my networked devices.
In my case, I believe this is due to broadcast packets.
A (logical or physical) point to point connection (device<-> IOC ) solve that problem.
I believe the broadcast packets are nothing less than the CA protocol itself ;-)
In a perfect world, one should have a network with OPIs and another network for controlled devices.
The IOCs are the bridges between both networks.
At APS, are controlled devices and OPIs on the same net?
devGpib problem Mark Rivers
Re: devGpib problem emmanuel_mayssat
Re: devGpib problem Pete Jemian
Prev: Re: devGpib problem Pete Jemian
Next: Re: devGpib problem Ron Sluiter
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
