1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Using Motor Record with READBACK Deadband and number of Retries.
To: Ron Sluiter <[email protected]>
Cc: EPICS <[email protected]>
Date: Fri, 16 Jul 2010 07:29:30 -0700
Ron Sluiter wrote:
Hello Ernest,
There is a feedback data flow diagram here <http://www.aps.anl.gov/bcda/epicsgettingstarted/specialtopics/motor1up.pdf> on page #17 that may clarify how the motor record feedback works.
Hi Ron,
Thanks for the reference.
This confirms how I thought "DRBV/RBV" is updated with respect to the state of "URIP".
After a move is completed, then we toggle URIP back and forth to observe the behavior of "MOTOR.RBV".
We observe that the LVDT value does not follow.
Is this because the latest reading from the LVDT will only show up after another move is executed?
My question arises as a result of how the motor record processes.
Thanks for your help. We will checkout the latest motor record software and do more testing.
Cheers, Ernest
Ron
Ernest L. Williams Jr. wrote:
We are currently using "Motor Record Version 5.9"
on some of our stepper motor applications.
We would like to use the motor software with USE READBACK enabled.
We are connecting our calibrated LVDT to the READBACK link.
What has been your experience in using this feature of the Motor Record?
When using READBACK inlink for Motor position sensing: (1) Selecting YES/NO does not update the motor record properly. Should the software actually copy the contents of MOTOR.VAL to MOTOR.RBV If READBACK is toggled back to "NO"
If the READBACK is set to "YES" then "MOTOR.RDBL", should be copied to MOTOR.RBV ?
Thanks in Advance,
Ernest
SLAC
Using Motor Record with READBACK Deadband and number of Retries. Ernest L. Williams Jr.
Re: Using Motor Record with READBACK Deadband and number of Retries. Ron Sluiter
Prev: Re: Using Motor Record with READBACK Deadband and number of Retries. Ron Sluiter
Next: RE: Soft IOC on Windows PC Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: EDM x-y plot crash Euan.Troup
