Hi Pawel,
On Friday 09 July 2010 13:53:04 [email protected] wrote:
> record(sub,"$(user):stopsub") {
> field(DESC,"SimpleTest")
> field(INAM,"SubInit")
> field(SNAM,"TestPrint")
> field(INPA,"$(user):goSub0.VAL")
> field(INPB,"$(user):goSub1.VAL")
> The question is, having the TestPrint function:
> long TestPrint(struct subRecord *psu) {
> return 0;
> how can I determine which button was pressed? I wanted to check both
> inputs and see which goSubx.VAL == 1 but I don't know how to get to the
> biRecord pointer using the subRecord pointer. Is there any way to do this?
You're not supposed to access the bi records directly, but the two input links
INPA and INPB of the sub record will have already read in the VAL fields of
those records before TestPrint() gets called. Your function can access the
values read at prec->a and prec->b respectively, and can also set prec->val or
any of the other prec->c through prec->l variables (the ones that don't have
their links set) to export any results.
HTH,
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
- Getting value of a PV from a subRecord function ppredki
Re: Getting value of a PV from a subRecord function Ned Arnold
<2010>
<2010>
