Subject: |
Re: VxWorks 6.7, MV5500 Re: EPICS R3.14.11, sequencer 2.0.12 crash on device support write error |
Andrew Johnson <[email protected]> |
To: |
[email protected] |
Date: |
Fri, 9 Jul 2010 10:03:48 -0500 |
Hello Kay,
On Friday 09 July 2010 07:51:33 Kasemir, Kay wrote:
> For the record, we found that our combination of VxWorks 6.7 and MV5500 BSP
> doesn't fully support C++ exceptions. The reported EPICS R3.14.11/sequencer
> 2.0.12 crash is not caused by problems in the code, but solely results from
> issues with the exception support.
I would be very interested to know whether the libCom/test/epicsExceptionTest
program detects this or not, and if not whether you could patch it so it does.
IIRC Ron Sluiter discovered a similar problem with C++ exceptions on the
target solaris-x86_64-gnu which was detected by that test routine; I'm
attributing that failure to gcc, building with the SunPro compiler on solaris-
x86_64 works fine.
You can run that test by loading bin/vxWorks-<cpu>/vxTestHarness.munch and
typing 'epicsExceptionTest'.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
- Re: VxWorks 6.7, MV5500 Kasemir, Kay
- VxWorks 6.7, MV5500 Re: EPICS R3.14.11, sequencer 2.0.12 crash on device support write error Kasemir, Kay
RE: linking to shared objects user libraries Mark Rivers
Re: linking to shared objects user libraries J. Lewis Muir
<2010>
<2010>
