Hi:
At the SNS we're using a version of vxStats where devVxStats.c looks similar
to this synapps release:
https://subversion.xor.aps.anl.gov/trac/synApps/browser/vxStats/trunk/vxStat
sApp/src/devVxStats.c
The cluster info support in there seems to cause memory corruption.
clustinfo is defined like this for 10 elements
974 #define CLUSTSIZES 10
975
976 static int clustinfo[2][CLUSTSIZES][4];
... but later filled for CL_TBL_SIZE elements:
997 void getClusts(int dataPool)
998 {
999 NET_POOL_ID pNetPool;
1000 int i;
1001 int test;
1002
1003 if (dataPool)
1004 {
1005 dataPool = 1;
1006 pNetPool = _pNetSysPool;
1007 }
1008 else
1009 {
1010 pNetPool = _pNetDpool;
1011 }
1012
1013 test = pNetPool->clTbl[0]->clSize;
1014 for (i = 0; i < CL_TBL_SIZE; i++)
1015 {
1016 /* first two are constant under current conditions and could
be
1017 * done just once per pool.
1018 */
1019 if (i > 0)
1020 if (pNetPool->clTbl[i]->clSize != (2 * test)) break;
1021 test = pNetPool->clTbl[i]->clSize;
1022 clustinfo[dataPool][i][0] = test;
1023 clustinfo[dataPool][i][1] = pNetPool->clTbl[i]->clNum;
1024 clustinfo[dataPool][i][2] = pNetPool->clTbl[i]->clNumFree;
1025 clustinfo[dataPool][i][3] = pNetPool->clTbl[i]->clUsage;
1026 }
1027 }
On our MV2100 CPUs, CL_TBL_SIZE evaluates to 11, which might be close
enough. With our new MV5500 setups, CL_TBL_SIZE is 16, which in one case
happened to cause getClusts() to clobber a save_restore structure.
Replacing all use of CLUSTSIZES with CL_TBL_SIZE fixes the issue.
We also changed
980 void minMBuf(int dataPool, int *ret)
981 {
982 int i;
983 double lowest = 1.0, comp;
984
985 i = 0;
986 dataPool = dataPool?1:0;
987 while (clustinfo[dataPool][i][0] != 0)
into
987 while (i < CL_TBL_SIZE && clustinfo[dataPool][i][0] != 0)
Kay
- iocStats (was: vxStats memory corruption) Ralph Lange
RE: SNMP & Electrical power grid or generation plant Dalesio, Leo
VxWorks 6.7, MV5500 Re: EPICS R3.14.11, sequencer 2.0.12 crash on device support write error Kasemir, Kay
<2010>
Re: SNMP & Electrical power grid or generation plant David Dudley
<2010>
