1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Tekronix and R&S drivers
To: Andrew Wagner <[email protected]>
Cc: [email protected]
Date: Thu, 08 Jul 2010 10:18:56 -0500
Andrew,
The TDS3000 support does not support the digital channels of MSO4000 series, but may work with the analog inputs with some minor changes to the device support. The TDS3000 also includes the TDS5000 series, so you can use that as a template to develop the analog side of the MSO4000 scopes. It looks like the MSO4000 follows most of the basic commands used in both the 3000/5000 series. The digital inputs I'm sure can be implemented, but you may want to create a whole new support for MSO4000 series, which the TDS3000 support would be a good starting point.
Nick DiMonte
APS, Argonne
On 7/8/2010 1:26 AM, Andrew Wagner wrote:
Hey everyone,
Has anyone written driver/device support for the the Tektronix MSO 4000 series of oscilloscopes? My model is specifically the 4054. Is this at all similar to the TDS 3000 for which support exists? I'm also interested in support for the Rhode&Schwarz ZVL Network analyzer. How generic are the commands that Tektronix, for instance, uses? Has someone written a base class with the common commands supported?
Cheers,
Andrew Wagner
Re: Tekronix and R&S drivers Andrew Wagner
Prev: Cross Compiling Linux for Embedded Systems Michael Abbott
Next: Re: Tekronix and R&S drivers Andrew Wagner
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Tekronix and R&S drivers Andrew Wagner
