Thank you,
Yes, that was the bug. It is rather embarrassing; I just could see it. It now works.
Zen
-----Original Message-----
Sent: Friday, July 02, 2010 3:00 PM
To: Szalata, Zenon M.
Cc: [email protected]
Subject: Re: aSub Question
in the snippet you send, INPA is missing a dollar sign for $(P):WF:REQUEST
On 07/02/10 17:38, Szalata, Zenon M. wrote:
> I have a waveform and an aSub records. I want to transfer data from the waveform to the aSub record and I am having difficulties with that.
> Here is my (simplified) waveform record:
> record( waveform, "$(P):WF:REQUEST"){
> field( DESC, "struct for request")
> field( FTVL, "CHAR")
> field( NELM, "132")
> field( FLNK, "$(P):AS:REQUEST")
> and here is my aSub record:
> record( aSub, "$(P):AS:REQUEST"){
> field( INAM, "asInitialize")
> field( SNAM, "asRequest")
> # field( INPA, "(P):WF:REQUEST")
> field( FTA, "CHAR")
> field( NOA, "132")
> field( FTVA, "UCHAR")
> field( NOVA, "132")
> When I process the waveform record, the asRequest routine gets called when the INPA field is commented out. However, when I uncomment the INPA field, asRequest routine no longer gets called when the waveform record is processed. Looking at the TIME field in the aSub record I can tell that the records is getting processed each time I process the waveform record, regardless if the INPA field is commented out or not.
> Is it not allowed to transfer array of bytes from one record to another?
> Is there a way to make that kind of data transfer?
> Thanks in advance,
> Zen
Matthieu Bec Gemini Observatory
Tel: +56 51 205785 c/o AURA, Casilla 603
Fax: +56 51 205650 La Serena, Chile
- aSub Question Szalata, Zenon M.
- Re: aSub Question Matthieu Bec
Re: aSub Question Andrew Johnson
Re: aSub Question Till Straumann
<2010>
<2010>
