1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: streamdevice ao from subroutine
To: Wesley Moore <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Thu, 01 Jul 2010 13:00:02 -0400
Admitting to your problems is how you fix them. lol. Once I got the ao to scan correctly, problem solved. Power supply is updating properly now. :)
Wesley Moore wrote:
All,
I'm using a subroutine record to calculate a drive voltage. The output of the subroutine is tied to the DOL of an ao record and used closed_loop as normal. The UDF of the ao is never getting cleared after startup. If I force UDF to 0 the ao processes and sends the correct stream to the power supply and changes the voltage. Any ideas on why UDF is not clearing allowing the ao to process as the drive voltage updates? I am missing something else?
Wesley
begin:vcard
fn:Wesley Moore
n:Moore;Wesley
org:Thomas Jefferson National Accelerator Facility;Free Electron Laser
adr:Suite 19, MS 18;;12000 Jefferson Avenue;Newport News;VA;23606;USA
email;internet:[email protected]
title:FEL Computer Scientist
tel;work:(757) 269-6033
tel;fax:(757) 269-6384
tel;pager:(757) 584-6033
url:http://www.jlab.org/FEL/
version:2.1
end:vcard
streamdevice ao from subroutine Wesley Moore
Prev: streamdevice ao from subroutine Wesley Moore
Next: EPICS or TANGO? Gorka Ronda
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
