1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: streamdevice ao from subroutine
To: EPICS Tech-Talk <[email protected]>
Date: Thu, 01 Jul 2010 12:54:51 -0400
All,
I'm using a subroutine record to calculate a drive voltage. The output of the subroutine is tied to the DOL of an ao record and used closed_loop as normal. The UDF of the ao is never getting cleared after startup. If I force UDF to 0 the ao processes and sends the correct stream to the power supply and changes the voltage. Any ideas on why UDF is not clearing allowing the ao to process as the drive voltage updates? I am missing something else?
Wesley
Re: streamdevice ao from subroutine Wesley Moore
Prev: Re: Re: error compiling base for rtems Silver
Next: Re: streamdevice ao from subroutine Wesley Moore
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: compiling synApps std Tim Mooney
