1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: strange ioc hangup
To: [email protected]
Date: Fri, 25 Jun 2010 13:34:58 +0200
On Wednesday 23 June 2010, Andrew Johnson wrote:
> Hi Ben,
> On Wednesday 23 June 2010 08:19:44 Benjamin Franksen wrote:
> > The question is: what does the CA server do after it outputs these
> > error messages? Could it be it does something to the socket that makes
> > vxWorks throw up hands and strike? Also, note the 10 second delay
> > between the CAS message and the vxWorks message.
> I agree with Larry,the "ei0: reset" message comes from the ei82596End
>  driver for the network chip, and is printed when its internal watchdog
>  timer goes off implying that the transmitter has locked up (according to
>  the comments in the source code, target/src/drv/end/ei82596End.c if you
>  have it).  I have certainly known this to happen if the network gets too
>  busy for the OS to handle all of the packets, which seems possible in
>  your circumstances.
> I'm not sure there's much you can do about it, other than try to enhance
>  the ei driver to improve the recovery code (if you have the source
>  code).
Hm, in our sources under target/src/drv/end I find no ei82596End.c, only
ln7990End.c. It says "END style AMD 7990 LANCE Ethernet network interface
driver" in the header comment. Is this where I should look?
Cheers
Ben
strange ioc hangup Benjamin Franksen
Re: strange ioc hangup Andrew Johnson
Prev: Pfeiffer Turbo Pump device driver Andrew C. Starritt
Next: Re: strange ioc hangup Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: strange ioc hangup Andrew Johnson
Next: RE: strange ioc hangup Jeff Hill
