1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: No monitor refresh [SOLVED]
To: [email protected]
Date: Wed, 23 Jun 2010 10:36:44 +0200
Hi all,
I want to mark this question as resolved.
There were at least two problems:
 - high CPU load,
 - improper I/O handling,
EPICS driver code was updated to run some ports in a separate thread and
that resulted in prompt response on monitors.
Thank you all for the help!
Best regards,
Hinko
On 05/11/10 12:26, Hinko Kocevar wrote:
> Hi all,
> I'm experiencing some strange behavior when using camonitor against an
> EPICS IOC.
> For some reason a CA_PROTO_EVENT_ADD response from IOC to CA client does
> not arrive, or arrives several minutes later after the PV value has
> changed. Note that first CA_PROTO_EVENT_ADD response is seen always,
> only latter CA_PROTO_EVENT_ADD responses do not arrive (or arrive late)?!
> This behavior is not seen always - sometimes the IOC would promptly
> respond with CA_PROTO_EVENT_ADD response when needed.
> I can see the CA_PROTO_ECHO requests/responses fine on the same
> camonitor channel link, only CA_PROTO_EVENT_ADD response is not seen.
> Inspecting the IOC I can see that the value did change (on lower levels)
> and caput response is also valid - updated with new value.
> I've ruled out the network problems, since the issue is raised even when
> using cross-over cable to communicate with the IOC. Actually even I
> update the value in the IOC shell, the camonitor is not refreshed!!
> Has someone experienced something similar?
> Are there some conditions that need to fulfilled in order for IOC to
> send a subsequent CA_PROTO_EVENT_ADD response(s)?
> TIA & HAND,
> Hinko
Hinko Kocevar
Technical support software engineer
Instrumentation Technologies d.d.
Velika pot 22, SI-5250 Solkan - Slovenia
T:+386 5 3352600, F:+386 5 3352601
mailto: [email protected]
http://www.i-tech.si - When your users demand stability
The information transmitted is intended solely for the addressee and may
contain confidential and/or privileged information. Any review, retention,
disclosure or other use by persons other than the intended recipient is
prohibited. If you received this in error, please notify the sender and
delete all copies.
No monitor refresh Hinko Kocevar
Prev: Re: MEDM installation instructions Andrew Wagner
Next: Re: MEDM installation instructions Pelaia II, Tom
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: No monitor refresh Hinko Kocevar
Next: Oddity with mbbo strings emmanuel_mayssat
