1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Channel Access Writes Failed on Asyn Record Writable Fields
To: "William Lu" <[email protected]>
Cc: [email protected]
Date: Wed, 16 Jun 2010 11:26:29 -0500
Glad it's working, but I don't understand the problem, because asyn
R4-10 should also work fine.
-----Original Message-----
Sent: Wednesday, June 16, 2010 11:00 AM
To: Mark Rivers
Cc: Ralph Lange; [email protected]
Subject: Re: Channel Access Writes Failed on Asyn Record Writable Fields
I finally got it working.  The problem turned out to be that there is
something wrong with the asyn library my code was linking to.  After I
linked my code to a different asyn library (R4-13), the asynRecord is
working.  Thank you very much for your help.  I really appreciate it.
William
Mark Rivers wrote:
> Note that DSET=(nil) and RSET=(nil).  That is wrong.
> It looks to me like the record was not initialized correctly.  Did you
> get errors in iocInit?
> Mark
> From: William Lu [mailto:[email protected]]
> Sent: Wednesday, June 16, 2010 10:04 AM
> To: Mark Rivers
Fields
> Here is what I got.  By the way, I am using asyn version R4-10.
> epics> dbpf LS450PS:asyn "test"
> filename="../dbTest.c" line number=295
> putFields are disabled - dbPutField error
> epics> dbpr LS450PS:asyn 10
> ACKS: NO_ALARM      ACKT: YES           ACMD: None          ADDR: 0
> AINP:               AOUT:               AQR: 0              ASG:
> ASP: (nil)          AUCT: autoConnect   BAUD: Unknown       BINP: 0
> BKPT: 00            BOUT: 0             CNCT: Connect       DBIT:
> Unknown
> DESC:               DISA: 0             DISP: 0             DISS:
> NO_ALARM
> DISV: 1             DPVT: 0x99daeb0     DRVINFO:            DSET:
(nil)
> DTYP: asynRecordDevice                  ENBL: Enable        EOMR: None
> ERRS: 0x99db190     EVNT: 0             F64INP: 0           F64IV: 0
> F64OUT: 0           FCTL: Unknown       FLNK:CONSTANT 0     GPIBIV: 0
> I32INP: 0           I32IV: 0            I32OUT: 0           IEOS:
> IFACE: asynOctet    IFMT: ASCII         IMAX: 80            IPTR:
> 0x99db0e0
> LCNT: 0             LSET: 0xfacbe0      MCTL: Unknown
> MLIS: 00 00 00 00 00 00 00 00 80 81 9d 09                   MLOK: 00
00
> 00 00
> NAME: LS450PS:asyn  NAWT: 0             NORD: 0             NOWT: 80
> NRRD: 0             NSEV: NO_ALARM      NSTA: NO_ALARM      OCTETIV: 1
> OEOS:               OFMT: ASCII         OMAX: 80            OPTIONIV:
0
> OPTR: 0x99db088     PACT: 0             PCNCT: Connect      PHAS: 0
> PINI: NO            PORT: sockserv      PPN: (nil)          PPNR:
(nil)
> PRIO: LOW           PROC: 0             PRTY: Unknown       PUTF: 0
> RDES: 0xfacc00      REASON: 0           RPRO: 0             RSET:
(nil)
> SBIT: Unknown       SCAN: Passive       SDIS:CONSTANT       SEVR:
> NO_ALARM
> SOCK:               SPR: 0              SPVT: (nil)         STAT:
> NO_ALARM
> TB0: On             TB1: Off            TB2: Off            TB3: Off
> TB4: Off            TFIL: Unknown       TIB0: Off           TIB1: Off
> TIB2: Off           TIME: c8 ba 9d 09 00 00 00 00           TINP:
> TIOM: 0             TMOD: Write/Read    TMOT: 1             TMSK: 1
> TPRO: 0             TSE: 0              TSEL:CONSTANT       TSIZ: 80
> UCMD: None          UDF: 0              UI32INP: 0          UI32IV: 0
> UI32MASK: 4294967295                    UI32OUT: 0          VAL:
> epics> asynReport 10 sockserv
> sockserv multiDevice:No canBlock:Yes autoConnect:Yes
>     enabled:Yes connected:Yes numberConnects 1
>     nDevices 0 nQueued 0 blocked:No
>     asynManagerLock:No synchronousLock:No
>     exceptionActive:No exceptionUsers 2 exceptionNotifys 0
>     interposeInterfaceList
>         asynOctet pinterface 0xfac6a0 drvPvt 0x99d23a8
>     interfaceList
>         asynCommon pinterface 0xfab7d4 drvPvt 0x99d1ce0
>         asynOctet pinterface 0x99d1d28 drvPvt 0x99d1ce0
>     Port 127.0.0.1:9099: Connected
>                     fd: 6
>     Characters written: 0
>        Characters read: 0
> Thanks,
> William
> Mark Rivers wrote:
>> Something is wrong, that should work fine.  Here's what I get on a
> record connected to a VXI11 driver:
>> epics> dbpf asynRecord.AOUT "test"
>> DBR_STRING:          "test"
>> epics> dbpr asynRecord 10
>> ACKS: NO_ALARM      ACKT: YES           ACMD: None          ADDR: 3
>> AINP: +1.0071E+21
>>  AOUT: test          AQR: 0              ASG:
> Unknown
> NO_ALARM
>> DISV: 1             DPVT: 0x8acb750     DRVINFO:            DSET:
> 0x163908
>> DTYP: asynRecordDevice                  ENBL: Enable        EOMR: End
>> ERRS: 0x8acba58     EVNT: 0             F64INP: 0           F64IV: 0
>> F64OUT: 0           FCTL: Unknown       FLNK:CONSTANT 0     GPIBIV: 1
>> I32INP: 0           I32IV: 1            I32OUT: 0           IEOS:
>> IFACE: asynOctet    IFMT: ASCII         IMAX: 200           IPTR:
> 0x8acb958
>> LCNT: 0             LSET: 0x8aced90     MCTL: Unknown
>> MLIS: 88 fb b0 08 d8 f6 b0 08 1f 00 00 00                   MLOK: 38
> b7 ac 08
>> NAME: asynRecord    NAWT: 4             NORD: 13            NOWT: 80
1
>> OEOS:               OFMT: ASCII         OMAX: 40            OPTIONIV:
> 1
>> OPTR: 0x8acb928     PACT: 0             PCNCT: Connect      PHAS: 0
>> PINI: NO            PORT: L0            PPN: (nil)          PPNR:
> (nil)
>> RDES: 0x8aa8db0     REASON: 0           RPRO: 0             RSET:
> 0x1638c0
> NO_ALARM
> NO_ALARM
>> TIB2: Off           TIME: 2010-06-16 08:48:57.406695215
>> TINP: +1.0071E+21\r\n                   TIOM: 0             TMOD:
> Write/Read
>> TMOT: 1             TMSK: 1             TPRO: 0             TSE: 0
>> TSEL:CONSTANT       TSIZ: 80            UCMD: None          UDF: 0
>> UI32INP: 0          UI32IV: 0           UI32MASK: 4294967295
>> UI32OUT: 0          VAL:
>> Please send the complete output of the following 2 commands:
>> ________________________________
>> From: [email protected] on behalf of William Lu
>> Sent: Tue 6/15/2010 4:46 PM
>> To: Ralph Lange
> Fields
>> The dbpf does not work.  It gives the error message as below:
>> epics> dbpf LS450PS:asyn.AOUT abc
>> Thanks,
>> William Lu
>> Ralph Lange wrote:
>>> Can you change the fields locally from the ioc shell (using "dbpf")?
>>> If yes, is Access Security enabled? Do you have write access rights?
>>> ("cainfo" on the client machine will tell you.)
>>> Ralph
>>> On Tue 15 Jun 2010 15:39:33 William Lu wrote:
>>>> I am having problems with channel access writes on asyn record's
>>>> writable fields such AOUT and PORT.  I created the following asyn
>>>> tcp/ip port and the asyn record:
>>>> In a startup iocsh script:
>>>>  drvAsynIPPortConfigure("sockserv","127.0.0.1:9099",0,0,0)
>>>> The asyn record:
>>>>  record(asyn, LS450PS:asyn) {
>>>>  field(DTYP, "asynRecordDevice")
>>>>  field(PORT, "sockserv")
>>>>  field(ADDR,"0")
>>>> After the record has been loaded to the ioc, I cannot write the
AOUT
>>>> or PORT fields of the record through channel access.  When I caput
> on
>>>> those fields, I got the error messages like the following:
>>>>> caput LS450PS:asyn.AOUT "abc"
>>>> Old : LS450PS:asyn.AOUT
>>>> CA.Client.Diagnostic..............................................
>>>>    Message: "Could not perform a database value put for that
> channel"
>>>>    Severity: "Warning" Context: "detected by:
>>>> devl17.acc.jlab.org:5064 for: LS450PS:asyn - with request
>>>> chan=LS450PS:asyn.AOUT op=1 data type=DBR_STRING count=1"
>>>> New : LS450PS:asyn.AOUT
>>>> What is the problem?  Any help would be gratefully appreciated.
>>>> William Lu
>>>> Jefferson Lab
>> Weiwei Lu
>> 757-269-7476
>> [email protected]
Weiwei Lu
757-269-7476
[email protected]
Re: Channel Access Writes Failed on Asyn Record Writable Fields William Lu
Re: Channel Access Writes Failed on Asyn Record Writable Fields Ralph Lange
RE: Channel Access Writes Failed on Asyn Record Writable Fields Mark Rivers
Prev: Re: Channel Access Writes Failed on Asyn Record Writable Fields William Lu
Next: Re: Channel Access Writes Failed on Asyn Record Writable Fields William Lu
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
