1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Channel Access Writes Failed on Asyn Record Writable Fields
To: "William Lu" <[email protected]>
Cc: [email protected]
Date: Tue, 15 Jun 2010 16:51:06 -0500
- caput again on the LS450PS:asyn.AOUT field gave the same error message as before.
I want to see the IOC output when you do that caput, after turning on the asynTraceMask in the previous step.  I think sure you should see some diagnostic output.
Please also send the output of the dbpr command.
Did you try Ralphs suggestion of doing the following from the iocsh prompt?
dbpf LS450PS:asyn.AOUT "hi there"
Sent: Tue 6/15/2010 4:43 PM
To: Mark Rivers
Subject: Re: Channel Access Writes Failed on Asyn Record Writable Fields
Thank you for the help.
- Sending a string from the asynRecord.edl screen gave me the error
message same as the error message I got from caput.
- The .ERRS field contains 100 zero's and these values do not change as
I tried to caput on the record's AOUT field.
- dbpr command gave no data pointing to the problem.
- "asynSetTraceMask sockserv 0 0xff" generated the following message on
the iocsh screen:
sockserv -1 exception 3 occurred calling exceptionUser
LS450PS:asyn: exception 3
as before.
At the point, I don't know the problem yet.
William Lu
Mark Rivers wrote:
> I am not sure what the problem is, but here are some ways to find out:
> - Load the medm screen for the asyn record (asynRecord.adl).  You can
> then interactively send commands to the port and observe the response
> and any error status.
> - The asyn record has an error string field (.ERRS) which may contain
> useful information.
> - Execute the following iocsh command to get all the record field
> values:
> dbpr LS450PS:asyn 5
> - Enable all debugging on that asyn port with the following iocsh
> commands
> asynSetTraceIOMask sockserv 0 0x2
> Then do your caput again or type in the asyn records .AOUT text widget
> and see if there is useful information in the output.
> Mark
> -----Original Message-----
> From: [email protected]
> [mailto:[email protected]] On Behalf Of William Lu
> Sent: Tuesday, June 15, 2010 2:40 PM
> To: [email protected]
> Subject: Channel Access Writes Failed on Asyn Record Writable Fields
> I am having problems with channel access writes on asyn record's
> writable fields such AOUT and PORT.  I created the following asyn tcp/ip
> port and the asyn record:
> In a startup iocsh script:
>   drvAsynIPPortConfigure("sockserv","127.0.0.1:9099",0,0,0)
> The asyn record:
>   record(asyn, LS450PS:asyn) {
>   field(DTYP, "asynRecordDevice")
>   field(PORT, "sockserv")
>   field(ADDR,"0")
> After the record has been loaded to the ioc, I cannot write the AOUT or
> PORT fields of the record through channel access.  When I caput on those
> fields, I got the error messages like the following:
>  >caput LS450PS:asyn.AOUT "abc"
> Old : LS450PS:asyn.AOUT
> CA.Client.Diagnostic..............................................
>     Message: "Could not perform a database value put for that channel"
>     Severity: "Warning" Context: "detected by: devl17.acc.jlab.org:5064
> for: LS450PS:asyn - with request chan=LS450PS:asyn.AOUT op=1 data
> type=DBR_STRING count=1"
> New : LS450PS:asyn.AOUT
> What is the problem?  Any help would be gratefully appreciated.
> William Lu
> Jefferson Lab
Weiwei Lu
757-269-7476
[email protected]
Re: Channel Access Writes Failed on Asyn Record Writable Fields Wesley Moore
Channel Access Writes Failed on Asyn Record Writable Fields William Lu
RE: Channel Access Writes Failed on Asyn Record Writable Fields Mark Rivers
Re: Channel Access Writes Failed on Asyn Record Writable Fields William Lu
Prev: Re: Channel Access Writes Failed on Asyn Record Writable Fields William Lu
Next: Re: Channel Access Writes Failed on Asyn Record Writable Fields Wesley Moore
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
