1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Burt problem on Fedora 11 64 bit for EPICS Base version 3.14.11
To: [email protected]
Date: Thu, 10 Jun 2010 16:08:00 -0700
Hi All,
    I am getting following error when I used burt restore tool, burtwb
ERROR: BurtProcessSnapshotFile() string column >ControlName< not in file >/tmp/CLS2010-159-0608-114007.gz100610-122455-30608clsop51<
The above command is called like "burtwb -f tmp/CLS2010-159-0608-114007.gz100610-122455-30608clsop51"
I am using the latest version of burt, which is 20080801 with Epics Base Version 3.14.11 on Fedora 11 64 bit operating system. I tried the burt version, 20070626 and the behavior is the same. Also, I tested on Fedora Core 8 with 32 bit operating system and there it is working fine, but I need to make it work for Fedora 11 64 bit. Could anyone help me in fixing the issue?
Thanks in advance.
Best Regards,
Ramu
Re: Burt problem on Fedora 11 64 bit for EPICS Base version 3.14.11 Andrew Johnson
Prev: Motor record release R6-5-1 Ron Sluiter
Next: Re: Burt problem on Fedora 11 64 bit for EPICS Base version 3.14.11 Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
